Push-Type Retainer Clips
Old Apr 23, 2010 | 08:13 PM
Stock2Autocrozz's Avatar
Stock2Autocrozz
Default Push-Type Retainer Clips
Anybody figured out any great way to replace these horrible pop rivets with something metal...or any other ideas?
This is especially the case with the engine BAY....something functional but aesthetically decent would be great
Last edited by Chebosto; Apr 27, 2010 at 10:51 AM. Reason: correcting the title for better search indexing
Old Apr 23, 2010 | 08:24 PM
350ZTheStandard's Avatar
350ZTheStandard
here's an idea.
What are you trying to do???
Old Apr 23, 2010 | 08:27 PM
calin's Avatar
calin
Originally Posted by 350ZTheStandard
here's an idea.
Old Apr 23, 2010 | 09:58 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
What pop rivets?
Old Apr 23, 2010 | 10:03 PM
Russ@Z1's Avatar
Russ@Z1
hahaha
I'm beginning to think the pop rivets are referring to the plastic pop clips.
Old Apr 23, 2010 | 10:05 PM
Waiz's Avatar
Waiz
1) Wrong forum
2) Those rivets are $2 a piece, I don't think it's worth the effort homes.
Old Apr 24, 2010 | 03:16 AM
There is a wide assortment of suitable hardware. These, for example, are pretty.
Old Apr 24, 2010 | 04:23 AM
Dr. Venture's Avatar
Dr. Venture
what is so horrible about them? Learn how to "pop" them the right way.
Old Apr 24, 2010 | 04:01 PM
Stock2Autocrozz
Well all joking aside......they are ugly and ineffective..especially when considering the engine bay battery and brake panels.
Old Apr 24, 2010 | 04:03 PM
Waiz's Avatar
Waiz
They are effective, otherwise we would all have our engine bay parts falling off the car.
I don't know of another company who makes a replacement, so it may be a business opportunity for you.
Old Apr 24, 2010 | 04:37 PM
crsracing19's Avatar
crsracing19
where do u get them at two dollars a pop i need like 20 but my dealer sells them for 5 a pop
Old Apr 24, 2010 | 05:32 PM
TreeFiddyZee
Do WHAAAAT!?
I got them for about $1 each off of eBay.
Old Apr 24, 2010 | 05:48 PM
MDK's Avatar
MDK
The last time I asked for them at the dealer they just handed me a bunch...
They really aren't that expensive either: http://www.courtesyparts.com/66810e-...8-p-17332.html
Old Apr 26, 2010 | 04:53 PM
user 83778's Avatar
user 83778
Got a dozen for $13 at local stealership. Double check with Infiniti too. Safelite broke most of mine off when replacing my front. =(
Old Apr 26, 2010 | 08:54 PM
terrasmak's Avatar
I have to order a bunch tomorrow when i hit the stealership up.
Old Apr 27, 2010 | 10:49 AM
Chebosto's Avatar
Chebosto
Pop Rivet is this:
what you are looking for are Push-Type Retainer Clips
Old Apr 27, 2010 | 01:39 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Originally Posted by Chebosto
Pop Rivet is this:
Thats what these are!
A dozen came with my Aerocatch hood pin set, i have no earthly idea why or what they are supposed to be used for concerning the hood pins.
My pins are on, and these things were never used...
Old Apr 27, 2010 | 01:56 PM
Chebosto's Avatar
Chebosto
they attach the aerocatch assembly to the surface of your hood.
u need to use a rivet attachment tool
so basically you drill holes through what you want to attach, push the thicker end of the pop-rivet through the hole, put the sharp nail looking thing into the rivet attachment tool, and then pull the lever.. you'll notice that the round end of the pop-rivet will suck up into the body and buldge out the cylinder.. you have to choke up with the tool on the nail looking part a couple of times until it pops off, then you have successfully attached the two pieces together with the rivet...
now in order to get rid of the rivet, you'll have to drill it out- so these are meant to be semi-permanent installations...
if your aerocatch pins are in place with bolts/nuts/screws. then that's fine...
Old Apr 27, 2010 | 06:01 PM
GeauxLadyZ's Avatar
GeauxLadyZ
Ahhh, ok, thanks Ches.
Actually, i would feel more comfortable with the integrity of my latches to hood with these in place as opposed to using the supplied hex screws/nylon locking nuts that i used. Looking at your explaination, however, it seems using such force on (when pulling rivets with tool) a carbon fiber hood may not yeild good results.
I take it these rivets may have been meant for a metal hood...
Old Aug 8, 2011 | 10:20 PM
350zx6r's Avatar
350zx6r
would these work?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
