I decided to take off my rear wiper since I hardly ever use it, plus it breaks up the flow of the hatch. I bought a metal hole plug from Lowe's along with a 1" bolt. My plan was to use superglue, but that ended up not working.
My blade would not budge after removing the nut. I thought it might need to be turned counter clockwise to loosen it, but that's when the shaft snapped off!
As you can see in this pic of the seal, when the top of the seal is flattened, the bottom bulges below the edges. This is why the eye of the eyebolt is needed to space the washer down.
