LOOSE PAX side DOOR handle
Old Feb 22, 2011 | 05:15 PM
Mcutali's Avatar
Mcutali
Default LOOSE PAX side DOOR handle
hi came out to my car tonight, passenger door handle is popped out, i popped it back in place had a metal lip i had to push back in the body, but now when i pull on it , its slight loose on the top, i can see a thin gasket in there now, only at the top it pulls away when i open door, is this something that can be adjusted my alldata does not show me.
Old Feb 22, 2011 | 07:36 PM
lgear080's Avatar
lgear080
i just broke my drivers door handle.
there is a fixed bolt that is glued into the handle assembly, mine broke.
yours might be working itself apart.
there are two grommets on the interior of the door at the jam.
pull the top one, try to tighten.
if it continues to pull away and can't be adjusted you might need a new one.
glgl
Old Feb 23, 2011 | 07:40 AM
Mcutali's Avatar
Mcutali
Default thanks
thank u sir, i do see the grommets i was wondering if they had relation to the handle. i will try this now
Old Feb 23, 2011 | 07:47 AM
Mcutali's Avatar
Mcutali
Default door handle
everything was tight, when i opened the handle i heard a little piece of something fall from inside the handle assembly into the inside of the door, so i must be needed a new one now. damn
Old Feb 27, 2011 | 10:32 PM
lgear080's Avatar
lgear080
sounds like plastic fail. the design of the handles is interesting, but apparently not fail proof. make sure you get the correct handle as both sides are unique.
Old Feb 28, 2011 | 07:23 AM
lowcountryz's Avatar
lowcountryz
Same thing happened to me recently, got a new handle from the dealer for about $80 and it only took about 10 mins to swap out.
350Z_Al
Oct 29, 2020 07:44 PM
wanderingstuden
Jan 28, 2016 07:03 PM
