Is this possible?
Old Mar 12, 2011 | 03:31 PM
ChriZTT's Avatar
ChriZTT
Default Is this possible?
I am in the process of refurbishing the interior on my '06 Z. I have taken the entire "middle section" (cluster, cubby, radio, and the panel that surrounds the shifter) out. I want to know if it is possible to detach all three gauge cluster covers (I'm talking about the black covers that surround each of the three gauges) from the waterfall portion of the interior. Thanks.
Old Mar 12, 2011 | 08:25 PM
Shermanator's Avatar
Shermanator
They are not meant to come off but i did it and it was no problem. If you look at the inside off the gauge covers you will notice that they have a plastic attachment that is melted to the center gauge cluster piece. What i did is i just broke them off and when i was finished with them i melted the plastic tab back on. Hope that makes sense. I did this on a 05 350z so it might differ slightly.
Old Mar 13, 2011 | 08:48 AM
ChriZTT's Avatar
ChriZTT
Thanks for the reply! Last night I ended up popping them off the same way you described. What did you use to heat the plastic to get it to stick again? Thanks.
Old Mar 13, 2011 | 08:58 PM
agunter33's Avatar
agunter33
i used hot glue to atach them, it works great and is e.z. to take off again
