New 350z Aftermarket Headlight..ugh!
Old May 25, 2011 | 02:21 PM
Blue Batmobile's Avatar
Blue Batmobile
Inventor
Blue Batmobile
smoke the top portion it'll look half decent.
B@t
Old May 25, 2011 | 08:46 PM
gregom's Avatar
gregom
True... it would look 'half' decent. But why go through all that work with dual projectors and not go dual HID projectors? Seems like a waste of effort if you ask me. Go big or go home, I guess is what i'm saying...
Old Aug 18, 2011 | 03:37 PM
NissanGeek's Avatar
NissanGeek
Default A few months late, but...
I have an '03 base. when i bought it, the headlights were cracked, yellowy and fogged up, horrible light output. i was going to buy the '06 headlights until i read the write-up on how to finish that swap, and the cost of those headlights are pretty high.
In the process of searching ebay for some used 06 headlights i stumbled across the ones at the beginning of this for $200 shipped. bought em. install took under an hour, and they look pretty good installed.
the next night while driving i noticed they were aimed quite high, where the light beam while stopped at a stop light was directly pointed at the street sign on the light pole. got home and tried to adjust them the same way as stock headlights with a screwdriver, and there doesn't seem to be an adjustment available. i'll take some pictures for you all to see them installed on a '03 black 350z, then take it apart to see if there is some other way to adjust them...
Old Aug 18, 2011 | 08:26 PM
FliPPER_Z's Avatar
FliPPER_Z
post some pics asap, thanks
Old Aug 18, 2011 | 08:43 PM
NissanGeek's Avatar
NissanGeek
first one is a night shot with low beams and running lights on.
second one is a picture i took while installing them, bumper cover dangling. i'll get a better shot of them installed in the daylight tomorrow.
both pictures taken with the camera on my android, sorry if you feel its too low quality...
Old Aug 18, 2011 | 09:02 PM
Al Kapwned's Avatar
Al Kapwned
^I'm sorry but those look like ricey crap.
Old Aug 18, 2011 | 09:29 PM
Waiz's Avatar
Waiz
Wow someone actually bought a set!
Thanks for posting those pics NissanGeek
Old Aug 18, 2011 | 09:42 PM
mr. sparco's Avatar
mr. sparco
I like them more than 03-05s, post up more pics.
Old Aug 18, 2011 | 10:06 PM
NissanGeek's Avatar
NissanGeek
They aren't even close to being as good as the later model HID's, but they do look a lot better than the stock base non-hids... especially cracked, yellow, foggy ones.
I could do without the halos, but I like the layout with the side by side high/low beams.
Old Aug 19, 2011 | 08:49 AM
NissanGeek's Avatar
NissanGeek
Default Daytime pictures of my "ricey crap" headlights
alright, so here they are. take 'em or leave 'em, i dont care. they were a huge upgrade from what i was dealing with before, and only $200, as opposed to $1200 for the '06 HID's.
Old Aug 19, 2011 | 09:53 AM
mr. sparco's Avatar
mr. sparco
I'd take those and change it up a bit just for fun since they were only 200 bucks.
Old Aug 19, 2011 | 11:29 AM
SirSpeedyZ's Avatar
SirSpeedyZ
I just got a set of 06s for $700 on ebay
worth $500 more to me
Old Aug 19, 2011 | 12:19 PM
NissanGeek's Avatar
NissanGeek
Do you have a model that came with HID's? I was under the impression that you need a new wiring harness, or need to spend some time running the extra 2 wires. Base models from 03 had a 6 wire plug, the 06 has an 8 wire plug. These headlights were a direct replacement.
Old Aug 19, 2011 | 12:23 PM
scoobyrex247's Avatar
scoobyrex247
Hey nissan geek could you post night time shots of the beam patter against a garage door and or of the pavement?
Old Aug 19, 2011 | 12:34 PM
gvulakh's Avatar
gvulakh
They look a little better with the sparco mod.
Old Aug 19, 2011 | 04:47 PM
NissanGeek's Avatar
NissanGeek
this is about 6' away from the garage door. i measured the top of the beam at 48"... still haven't figured out how to adjust them down.
Old Aug 19, 2011 | 07:31 PM
scoobyrex247
thank you! The cut off looks to be pretty sharp and the step looks good. However the burn-spot I reckon is too intense and too far apart from ea. other.
+1 on the aiming them lower. I think they should be around the 27 - 28in height. keep up the good work OP.
Old Nov 6, 2011 | 02:50 PM
  #38
scoobyrex247
bump, could anyone link the thread where a Redline Z owner installed the other set of ebay lights with the L-shaped LEDs. I can't seem to find that thread.
The guy had to trim some 168 lamp sockets to make it work.
Old Nov 6, 2011 | 03:21 PM
  #39
Cux350z's Avatar
Cux350z
hatersgonnahate
that was my thread. I deleted it after a mod trashed it up by merging a bunch of junk threads with it. I asked for him to unmerge be he denied the request.
Old Nov 6, 2011 | 03:35 PM
  #40
scoobyrex247
that would explain why after searching for countless key word searches and going through the last 20 pages I couldn't find anything. I thought i was going nuts.
Dear mods, Cux350z's thread did offer and add something new to the slew of ebay headlights threads. Mainly he actually bought and explained the install with the important beam projector pictures. The ones on this particular thread are of a different design. If possible could a mod combine his thread with this one.
At least that way people would have a way two compare these two newer led / projector headlights without doing too many searches. Thanks.
