Cup-kit Suspension Tank Mounting Location?
Old Nov 15, 2011 | 10:57 PM
350monZter's Avatar
350monZter
Default Cup-kit Suspension Tank Mounting Location?
Ok so I just bagged my Z.
I'm looking for places for my tank.
Does anyone have any good photos of where you put yours?
Thanks
Also any of your No2 tanks
thanks
JUST SO EVERYONE KNOWS
THIS IS A CUP KIT !!!
NOT AN AIRBAG KIT.
Old Nov 15, 2011 | 11:21 PM
midz350's Avatar
midz350
trunk
Old Nov 15, 2011 | 11:33 PM
terrasmak's Avatar
Can't say i would mount tanks. Just remove the bags, your car will be better off.
Old Nov 16, 2011 | 12:55 AM
redsun350z's Avatar
redsun350z
+1.
Old Nov 16, 2011 | 03:47 AM
winchman's Avatar
winchman
I had my No 1 and No 2 tank buried in my back yard when I lived in the country.
Old Nov 16, 2011 | 03:51 AM
MUZZY's Avatar
MUZZY
Get a duel exhaust with canisters then there will be plenty of room under the car. That's ware I putting mine
Old Nov 16, 2011 | 06:24 AM
nismo_nate's Avatar
nismo_nate
heres a picture from one of our members here on my350z. he's in socal too
Old Nov 16, 2011 | 07:34 AM
skakemokid's Avatar
skakemokid
Id try putting it in the glovebox area..
Old Nov 16, 2011 | 08:30 AM
350monZter's Avatar
350monZter
There are no bags.
It's a bag-less cup kit
Old Nov 16, 2011 | 08:59 AM
bmccann101's Avatar
bmccann101
full cup kit is sick made and daymn expensive.
OP, if you arent using your factory sub location, pull the rear speaker covers, and then pull the plastic off the trunk/glovebox opening. Theres a TON of room inside the area behind your drivers seat, right above your gas tank. Also, you can mount it to the trunk floo where your spare would be and it will only stick up a few inchesthen.. needs the trunk floor plastic and carpet cut of course.
IF youre rocking cup kits, im sure you dont half @ss things, so do a nice install or a stealth install IMHO..
btw... what cups are you using?
Old Nov 16, 2011 | 09:17 AM
TPete19's Avatar
TPete19
Agreed! I mounted an amp rack in there with two large amps and a cap. There's quite a bit of space, but it is one that is tough to work in. I built the rack and mounted the amps out of the car and then slid the setup in.
If you need even more space, you could remove the glove compartment innards from the passenger side area as well.
Old Nov 16, 2011 | 11:00 AM
Chebosto's Avatar
Chebosto
away from Solid Snake, that's for sure.
Old Nov 16, 2011 | 11:04 AM
bmccann101's Avatar
bmccann101
True dat.
If I had a tank..id put it in fwd gear in the CA 405 during rush hour.
Old Nov 17, 2011 | 10:06 AM
350monZter's Avatar
350monZter
I went to Platinum VIP in Irwindale
they set me up with a Phantom Cup Kit
This is by far...the best shop for everything
Old Nov 21, 2011 | 02:22 PM
350monZter's Avatar
350monZter
I was hoping to hide it as much as possible.
Does anyone have stealth photos????
The tank is a little too big for the glove
Old Nov 21, 2011 | 02:48 PM
ocdz's Avatar
ocdz
dal35 on g35driver has a cup kit. his is pretty stealth mounted in the trunk but he has a custom trunk interior done also. Tried to find a picture but couldn't. how badly do you need your spare tire?
Old Dec 1, 2011 | 11:40 PM
350monZter's Avatar
350monZter
*bump*
Old Dec 6, 2012 | 03:25 PM
Kwame's Avatar
Kwame
Disregard...
Old Dec 6, 2012 | 03:36 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
There's my install thread
Old Dec 6, 2012 | 08:27 PM
Kwame's Avatar
Kwame
Got in contact with manufacturer who provided a well illustrated manual.
