Help with CRB repair
dudes, I need some help. I just noticed that I have a chip out of the protective resin on my Veilside carbon lip. It is about the diameter of a centimeter and has gone all the way through to the fiber weaving. What can I do to repair this and prevent it from getting any worse? Please, any expertise in this area would be greatly appreciated.
Thanks,
-Sean
Thanks,
-Sean
Take it off and fiber glass it from the back side. and then paint what shows through from the front black. Or you could apply a thin sheet of CF on the back too. There isnt really much you can do about it other than that.
a chip in the resin that just goes to the fiber and the fiber isnt damaged? it probably is not worth fixing. the only thing that will happen is the weave will fade from not having any UV protection in that spot. I can fix it for you if you happen to be in norcal, the cost of shipping isnt really worth it.
dragon11689
Sep 7, 2015 02:47 PM
