Rear cubby removal
Old Feb 10, 2012 | 04:59 AM
mpthree50's Avatar
mpthree50
Default Rear cubby removal
Hey guys, I was wondering if anyone has any info on removing the rear cubby's, specifically the smaller cubby. I tried to search for a thread but came up with nothing. Just curious if anyone has any tips or easy instructions for pulling all the plastic apart. Any info helps, thanks!
Old Feb 10, 2012 | 07:42 AM
SA Z-boi's Avatar
SA Z-boi
the smaller cubbies should just pull out. Everything is attached with tabs so it comes out pretty easily. I would take both seats out before you start stripping.
Old Feb 10, 2012 | 07:52 AM
mpthree50's Avatar
mpthree50
heh thats a lot easier than I expected, thanks for the info.
Old Feb 10, 2012 | 07:57 AM
bmccann101's Avatar
bmccann101
no need to take seats out to remove even the entire rear.
Its very easy.
Things only break when you're reassembling things and smashing down clips when theyre not in the right holes.
use a wide grip on the plastic pieces to grab a larger broad area and pull.
If youre trying to remove just the flip down boxes, open the door, then pull it out.
Thats it.
If youre trying to remove the hinged glovebox cubby, move both seats fwd and lean them on the dash...remove the plastic that goes under the side windows and seat belt by pulling and remove each from the car.
Then remove the plastic that goes along behind the seat backs, take care to unhook the connector for the cigaretter lighter power adapter in the middle, remove from car, and then the cubby has 10mm bolts all along the front, and also 2 in the back corners inside, thats it.
3vilbunny
Jul 18, 2017 05:10 PM
