Can Someone Help Me Out With A Reverse Wire Problem?
hey guys, so today i was hooking up my backup camera, keep in mind that ive done this on dozens of cars successfully so i pretty much know what im doing. So on this forum i read the color code guide and it said that the light green wire in the driver kick panel was the reverse wire, so i went ahead and tapped in that wire for my headunits reverse function. I started the car up and my headunit did not go into reverse mode, so i google the color of the reverse wire to make sure i was correct and on ********* it said that the green with white stripe was the reverse wire, i went ahead and tapped into that and it still didnt work, (ended up being the left turn signal wire) i know that because everytime i use my left turn signal my headunit goes into reverse mode and when i take the signal off the reverse mode turns off, so im in a bit of a pickle here, can someone PLEASEEEEEEE clarify the color of the reverse wire and its nearest location by the headunit on a 2004 350z base model. thanks in advance.
