Lights are giving me problem
Old Nov 23, 2012 | 09:10 AM
Mr350kv's Avatar
Mr350kv
Default Lights are giving me problem
Hello guys! Well I've been having problems with my HID lights recently and I cannot figure what is wrong. I bought after market bulbs about 4 years ago, and one side seems to have trouble turning on. So I decided to change them out and replace the bulbs again. But this time the same light would turn on and then eventually off again. I tried flickering the lights to get back on but same affect. Some times both lights turns off and not turn back on.
I was curious what was the problem? Is it a fuse? New ballast? some input would be greatly appreciated.
Old Nov 23, 2012 | 10:13 AM
aboveliquidice's Avatar
aboveliquidice
Start with the cheapest, easiest to replace. Them work your way up.
Are the lights seated right? Condensation anywhere? Then fuse, bulb, wiring, ballast.
Old Nov 23, 2012 | 10:18 AM
ronn1's Avatar
ronn1
Sounds like bad ballast I would replace both at the same time.
Old Nov 23, 2012 | 11:18 AM
bmccann101's Avatar
bmccann101
i have tons of HID experience, and this ^ is an accurate statement.
You can find remanufactured OEM ballasts on ebay cheap and are "simple" to replace.
Old Nov 24, 2012 | 06:28 PM
Mr350kv's Avatar
Mr350kv
Thank you everyone!
Uriyo_
Sep 8, 2021 08:46 AM
