06 350z Roadster, Passenger Door locked and closed, Need advice on opening
Old Jul 9, 2013 | 11:30 AM
icrashcars's Avatar
icrashcars
Default 06 350z Roadster, Passenger Door locked and closed, Need advice on opening
Did the usual searching on this site and google, but to no avail.
Passenger door is locked and closed. Sounds like a bad actuator, can hear it move, but doesnt unlock. I cant find a way to get the interior panel off while the door is closed.
Any suggestion or links I should read?
Old Jul 9, 2013 | 01:44 PM
sry110's Avatar
sry110
When you manually move the rocker switch from locked to unlocked positions, what happens?
Not sure how to get that panel off without having the door open, though.
Old Jul 10, 2013 | 07:47 AM
icrashcars's Avatar
icrashcars
When I move the manual rocker switch, it makes a slight clicking noise, but does not unlock.
Old Jul 10, 2013 | 02:36 PM
myork's Avatar
myork
Sounds like the lock rod has disconnected from the latch, might be slim jim time for you.
If your worried about breaking or scratching your window or paint, you may need to take it to a good locksmith or the stealership.
Old Jul 11, 2013 | 09:45 AM
mknZ's Avatar
mknZ
Drop the top and Dukes of Hazzard that b*tch! Nah I would take it to the dealership. Think it's nearly impossible to take the panel off with the door closed.
Siqcology
Sep 18, 2019 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
Mikey R6
Sep 19, 2015 01:48 AM
Obeorangekenobi
Sep 11, 2015 07:17 AM
AP350z223
Sep 8, 2015 04:38 PM
