Z Speed Undershroud
Old Jul 25, 2013 | 05:34 PM
deezz's Avatar
deezz
Default Z Speed Undershroud
Old Jul 25, 2013 | 05:36 PM
Mikeyyy's Avatar
Mikeyyy
Aluminum undershroud!
Old Jul 25, 2013 | 05:43 PM
deezz's Avatar
deezz
my man....
Thank you!
Old Jul 25, 2013 | 06:21 PM
mattleegee's Avatar
mattleegee
zspeed sells it
fits perfect, even with my aerosync front bumper
Old Jul 25, 2013 | 07:13 PM
dcains's Avatar
dcains
Get one. The first, and one of the best, upgrades I ever installed on my '08. Only the genuine one from Z-Speed, not the eBay knock-off. Huge difference in quality for a tiny difference in price.
Old Jul 25, 2013 | 07:33 PM
BigBlue's Avatar
BigBlue
Do you know if these clear the bigger dia. front sways like Hotchkiss? I've got a ss undershroud that a few of us had a G owner fab up for our Zs/Gs and it is nice, but when I went with Hotchkiss sways it rubbed/wore some of the bottom of the swaybar; never rubbed the stock swaybar. I just put the stock one back on as the ss one now sits.
Old Jul 25, 2013 | 07:35 PM
dcains's Avatar
dcains
Plenty of clearance on mine.
Old Jul 25, 2013 | 07:38 PM
BigBlue's Avatar
BigBlue
cool, what type of sways do you have?
Old Jul 25, 2013 | 07:39 PM
dcains's Avatar
dcains
Hotchkis, with Powergrid end links.
Old Jul 25, 2013 | 07:48 PM
BigBlue's Avatar
BigBlue
Thanks, I have the Powergrids also. I'm going to look these undershrouds up and most likely order one soon. Thanks for the info.
Old Jul 25, 2013 | 07:55 PM
dcains's Avatar
dcains
No trouble.
Old Jul 25, 2013 | 09:23 PM
DarkCreep's Avatar
DarkCreep
What difference do these make?
Old Jul 25, 2013 | 09:38 PM
dcains's Avatar
dcains
In terms of performance, none, really. But, they're infinitely more durable than the crappy vac-formed OEM plastic undertray, which will eventually shred at its bolt holes and start to drag on the ground. It's also more protective of the underside of the engine bay, and either tray is necessary for proper air flow through the a/c condensor and radiator. And, oil and filter changes are much easier. See that little trap door at the back? Take one bolt out, and you've got full access to your oil drain and filter while the tray remains in place. Finally, it looks great.
One more thing, it also provides more rigid support for the front bumper, which really is needed at the bottom edge, and isn't provided by the OEM plastic tray.
Old Jul 25, 2013 | 09:52 PM
BigBlue's Avatar
BigBlue
I was reading about it and it "does" clear the larger swaybars, vents air through oil pan area for better cooling and these also can help the radiator be more efficient at least some; I like the stiffness that they provide to the bumper area.
Old Jul 25, 2013 | 10:03 PM
dcains's Avatar
dcains
This is one of those mods which just doesn't have a downside.
Old Jul 25, 2013 | 10:08 PM
Touge Z's Avatar
Touge Z
now where is the cheapest place to buy the z speed under tray?
Old Jul 25, 2013 | 10:12 PM
dcains's Avatar
dcains
http://www.zspeedperformance.com/ZSp...d-zsp20001.htm
Old Jul 25, 2013 | 10:30 PM
Touge Z's Avatar
Touge Z
are they a vendor on here?
Old Jul 25, 2013 | 11:00 PM
dcains's Avatar
dcains
I think they're "ZSpeedPerformance", or something similar.
Old Jul 26, 2013 | 10:02 AM
BigBlue's Avatar
BigBlue
Just ordered one from ZSpeedPerformance! It will be nice no doubt.
