works bell standard hub
Old Nov 19, 2014 | 11:09 AM
nizmo_0385's Avatar
nizmo_0385
Default works bell standard hub
Will the works bell standard hub keep the steering wheel in the oem location?
Old Nov 20, 2014 | 02:05 PM
nizmo_0385's Avatar
nizmo_0385
Buuuuuuuuump
Old Nov 28, 2014 | 08:44 AM
guitman32's Avatar
guitman32
It all depends on if you are using a quick release and the offset of the aftermarket wheel.
If no quick release and flat wheel you'll be close.
Old Nov 30, 2014 | 02:06 PM
nizmo_0385's Avatar
nizmo_0385
Thanks I thought it'd be close to stock. I went with nrg hub with nrg spacer due to cracking issues with pot metal wb hub. Nrg is perfect with spacer and no.quick release and turn signals turn off like oem.
_bit
Oct 2, 2015 07:49 AM
