Tail lights out/brake lights working-
Old Jan 4, 2017 | 03:56 PM
hologrvm's Avatar
hologrvm
Default Tail lights out/brake lights working-
So, tail lights are out, brake lights are working...
i noticed when installing my hid kit that the connection to the factory harness looked bad, the clip was broken and it looked shotty with black almost burned looking stuff going on
got it tight with a zip tie to make that headlight work, but after a few days the headlamp on that side quit and also my tail lights.
What is that connector called? Would that cause my tail lights to go out? I heard something about checking some fuses at this fuse box BEHIND the battery, but I haven't located one BEHIND it, there's a small one in front of the battery and one inside by the clutch pedal.
Old Jan 5, 2017 | 05:18 AM
travlee's Avatar
travlee
Master
you prob shorted something out or blew some fuses.... you will just need to track it down
