LED Switchback Wiring
I've looked all over and can't find a clear explanation on how to wire my switchbacks. I have an 03 DE and the wires coming from the switchbacks are red black and yellow. Where do I tap in to wire them? Turn signal? Parking light?
They're from ijdmtoy, but that doesn't matter. I listed the connection wires coming from a black box that the led strip plugs into. Does anyone know how to wire them as a switchback for turn signal, and be able to turn them on and off? I assume I need to tap the parking light and turn signal?
Dude how do you expect anyone to help you. All we know is that you have ijdmtoy lights with 3 wires; red, black, and yellow. You've given us zero information to even try and help you. I assume they came with instructions unless you bought them used, and even if they are used did you even try googling? iJDMTOY is a pretty big company from what I've seen so I doubt you're the first to buy these lights.
If you're really still stuck, here's your spoon: http://bfy.tw/9Vhk
Should have said that to start. This may damage the module, or blow some fuses, but here's what I'd try. The black wire goes to ground. Then splice one of the others to a running light and the other wire to signal light - in both cases, the power, not another ground. See what happens. If it works at all, you may be lucky and have it correct. If not, switch those last two wires and try again.
Thanks for the help.
iJDMtoy. The lights I bought are universal, which is why I came here to see if anyone else has done it. The overall look is similar to this:
https://www.instagram.com/p/BPMT50KBYX4/?hl=en
Step by step instructions, with photos are on their website.
http://store.ijdmtoy.com/Audi-Style-...uide-a/648.htm
http://store.ijdmtoy.com/Audi-Style-...s-p/50-055.htm
