IPDM headlight relay
Old Nov 18, 2017 | 05:58 PM
nshelton6506's Avatar
nshelton6506
Default IPDM headlight relay
I did a quick search and could not find much on the topic. My headlight relay in my IPDM does not ground out, i believe it is a short in the IPDM. A local on craigslist is selling an ipdm from a 03 Z, i have a 06 6mt. Is there anything i should know about swapping them? Does anyone think the ipdm is not at fault?
Old Nov 18, 2017 | 06:35 PM
BakaN20's Avatar
BakaN20
Do the auto active test.
http://www.titantalk.com/forums/tita...tive-test.html
Also, you can switch the relays from each other. So take the headlight relay and replace it with another one to see if that solves your problem.
I believe you can use any ipdm as long as it is from a coupe, manual, and 03-06. I thought i had issues with my ipdm before and I purchased a bunch of used ones and they were interchangeable from what I can remember.
Old Nov 18, 2017 | 06:39 PM
nshelton6506
I have done the auto active test and they dont come on. Also I tried switching relays and it did not help. I currently have a wire jumping the relay and running to a toggle switch to turn the headlights on. If the ipdms are swapable i think it would be worth the 40 bucks to try it.
