Is it possible to make the red tail lights on the car the turn signal?
Old Jun 20, 2019 | 10:51 AM
MBouzari909's Avatar
MBouzari909
Default Is it possible to make the red tail lights on the car the turn signal?
Hello everyone. Recently i bought new custom headlights and for some reason, the turn signal ticks fast as if the bulb is out. I thought about how it might be fixed if there was a way to hook up the turn signal wire to the tail light, allowing the tail light to flash when the turn signal is hit. Let me know what you guys think.
Old Jun 20, 2019 | 02:08 PM
KornerCarver's Avatar
KornerCarver
If you have OEM LED tail lights, you can get a module from Diode Dynamics that will make your tail light also function as a direction indicator. https://www.diodedynamics.com/tail-a...odule-diy.html
Old Jun 20, 2019 | 03:43 PM
MBouzari909
Thank you 🙏
Old Jun 22, 2019 | 07:48 AM
NissanZcrazy's Avatar
NissanZcrazy
You need to have a led resistor wired in,That’s what’s causing the hyper flash
Old Jul 1, 2019 | 01:16 PM
Desert Z's Avatar
Desert Z
To answer your tail light question, it can be done without LED conversion. It takes some knowledge of wiring/electronics.
chad_everson
Lighting
Mar 16, 2013 02:25 AM
831slowest350
Aug 12, 2011 08:42 AM
1 MEAN Z
Sep 23, 2010 06:04 PM
