Putting in new gauge cluster, and it only works sometimes
Old May 10, 2023 | 08:25 PM
omldylan's Avatar
omldylan
Default Putting in new gauge cluster, and it only works sometimes
I have an extra nismo gauge cluster that I wanted to replace my regular one with (my car is not a nismo). When I originally tried it, the cluster lit up and everything but the gauges didn't work so I put the regular back in. Earlier today I tried again, and it actually worked. Everything was working right except the rpm needle was a bit sticky but otherwise it all worked. Then I turned it off for about 30 minutes and when I turned it on again it lit up but the gauges don't work right. The rpm and the mph don't move at all and the temp and gas gauges randomly move periodically. It will also sometimes beep at me. I'm wondering what I could try to get it to work properly.
Old May 11, 2023 | 06:06 AM
i8acobra's Avatar
i8acobra
You could put the correct gauge cluster in. Pretty sure that'll work.
Old May 11, 2023 | 10:08 AM
omldylan's Avatar
omldylan
thanks bro what would i do without you
Old May 11, 2023 | 12:59 PM
travlee's Avatar
travlee
Master
He gave you the correct answer.
Old May 11, 2023 | 01:49 PM
omldylan's Avatar
omldylan
aight mister premier member my bad
Old May 11, 2023 | 02:17 PM
travlee's Avatar
travlee
Master
No problem balla on a budget
Old Jun 17, 2023 | 04:16 AM
RichardMendoza's Avatar
RichardMendoza
Thanks for the advice, you saved my day.
dabazi22
Dec 13, 2013 06:18 AM
m3powerrr
56
Oct 1, 2013 10:54 PM
pgraham86
Jul 5, 2010 12:44 PM
veilside350zTT
Feb 6, 2006 08:45 PM
veilside350zTT
