Wiring a switch for LED sidemarkers
Originally posted by alphared
Why don't you just use a SPST relay. Connect the ON to the parking light power (for the led, not actual parking lights) and the switching part to the blinker's ground (or power).
Then you can just connect the parking light ground (again for the led) to the switch. If the switch is on, power is supply to the LED's (if you turn on the regular parking light) So if there's power going to the LED, this will turn on the relay and connect the blinker's ground (or power) allowing the blinkers to work.
Not sure what Voltage or current is being supplied to the Led sidemarkers, but you can probably find a small on at Radioshack with the right Voltage & Current rating for about $5.
gnd
|--===RELAY +----Parking Light--Switch
....|--------Blinker's gnd
(don't mind the periods, it's just for spacing, the Relay switch is 2 wires, one to gnd the other to blinker's gnd)
the Relay power goes to the parking light
the Switch on the relay goes to gnd and blinker's gnd
So if parking light is on, Relay switch closes allowing blinkers to work.
gnd
Originally posted by Conceyted
I understand it all except the relay part. What is this being used for? Lets say I just have 1 set of wires... parking light positive and ground wire... can i just wire the switch to the ground wire without worrying about a relay?
This is what I was referring to
It's a 1amp SPST relay (obviously the led current is higher than 1amp, but this gives you an idea)
I wired my switch tonight, yes before I even have my LED sidemarkers. I ordered those as well, but my switch is in the ashtray/coinholder compartment, thanks to dave079 for the help! Everything looks good and is hidden, now i just need to get those led sidemarkers in and see if the switch works correctly. I did what ares suggested, no current used, just took the ground wire and will wire the two led sidemarker grounds together and run them to the switch, that way if they arent grounded they dont light up!
wait... in your relay setup, you have it blinking with the turn signals, but powered by the parking light... I may be missing something(probably am
) but arent you accomplishing the same thing as wiring the LEDs directly to the turn signal power? except your using the parking light power... it would light up only with the turn signals, and only when the parking lights are on.
I have created a circuit that will take input from parking lights and blinkers and control the led sidemarkers => on with parking lights, blink with blinkers, or alternate with blinkers when parking lights are on.
I thought about trying to sell these but decided that it wasn't worth the effort (time to build vs. cost/value). If anyone is interested in some that I've built or a kit or whatever - PM me.
As far as switching this circuit, you could put a switch in the ground line to accomplish a forced off state.
The only area of concern, as far as police are concerned, is removing all amber reflectors from the front of your car or using leds that are other than amber/yellow. But if you want to be sure, this is the best way, go talk to the local and/or state police to get their take on what you want to do. Ignorance of the law usually doesn't fly.
Hope you enjoy your leds - they're a nice touch to the car.
Originally posted by 2004z
FriscoZR, I'm interested. Sent you a PM.
Originally posted by MySunset350Z
couldnt we just set up something using basic logic gates?
i'll see if thats possible later on today.
just to check for anyone that uses them, are these able to regulate current up to 150mA atleast? I know that isnt much, but just want to be sure, most setups for LEDs would be 20mA, but not luxeon LEDs.
looks good though.
looks good though.
looks good though.
looks good though.
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
Beater350z
Sep 9, 2015 03:36 PM
