Need to remove a plastic panel
Old Mar 30, 2004 | 09:36 PM
wren57's Avatar
wren57
Default Need to remove a plastic panel
I need to remove the plastic piece on the underside of the rear strut bar. My sub box fits tightly under there against it and rattles like CRAZY because the box transfers the energy to the plastic... and ideas?
Old Mar 31, 2004 | 08:01 PM
rouxeny's Avatar
rouxeny
Some sort of foam insulation may be easier?
Old Mar 31, 2004 | 08:06 PM
wren57's Avatar
wren57
Heh, I was just gonna let this post drift off the map and disappear without a response. For those interested, I ended up removing the underside panel of the rear strut bar. I gained about 1/2" clearance, and it is NOT noticeable unless you stick your head in the hatch and look up. I also noticed the rattles aren't from the car, but from air leaks due to the subs not being entirely sealed into the box. MUCH easier problem to fix. I am, needless to say, a happy man tonight.
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
