Custom modified Shift Light
Old May 27, 2004 | 07:29 PM
ChrisMCagle's Avatar
ChrisMCagle
Default Custom modified Shift Light
Finally finished the new mod with the help of big_al.
What do you think?
At Idle:
Old May 27, 2004 | 07:30 PM
ChrisMCagle
Default And on
At the set RPM:
Old May 27, 2004 | 07:42 PM
ZZZealous007's Avatar
ZZZealous007
looks good. it seems very bright though. does it bother you when it triggers?
Old May 27, 2004 | 07:54 PM
rodH's Avatar
rodH
I am more impressed by the Nismo gauge, that is sweet!!!
Old May 27, 2004 | 07:58 PM
NY 350Z's Avatar
NY 350Z
i have a pivot shift light just like that, i was gonna put it in the same location. howd you hook it up.
-Chris
Old May 27, 2004 | 07:59 PM
joonsuh012's Avatar
joonsuh012
how can you make that? can you do it for my car too?
i will buy you nice dinner....keke
Old May 27, 2004 | 09:24 PM
350ed's Avatar
350ed
Professional
Yo, hook us up with the install/parts details!
Old May 27, 2004 | 09:25 PM
Canadian350Z's Avatar
Canadian350Z
Time to get some gas!!!
Old May 27, 2004 | 11:19 PM
hndumafia's Avatar
hndumafia
that's not the actual nismo gauge cluster though, is it? i thought the nismo one went up to 180, or something higher than stock?
Old May 27, 2004 | 11:25 PM
aaaaa's Avatar
aaaaa
i think so too, i think he just open the gauge cluster and put the nismo sticker or something...
anyways it looks good tho!
Old May 28, 2004 | 08:05 AM
ChrisMCagle
Bingo!
I figured that as long as I had the cluster in about 20 pieces on my kitchen table, I had a good opportunity to make mine a little unique.
I have a write up for the shift light mod all typed out but it will have to wait a while. I promised Alan I wouldn't post any directions on the mod until he finishes the gig he is working on with the NorCal guys.
If anyone wants to check mine out, I'll be glad to show you. I'll be at the drag races at the CA Speedway tomorrow and the Stillen event on the 5th.
-Chris
Old May 28, 2004 | 08:15 AM
ChrisMCagle
The picture makes it look WAY brighter than it really is, but it is bright enough to see quite well in daylight. The LED bracket is on a pivot mount so I can angle it up or down so it won't be right in my eyes at night. The whole thing cost about $30.00 for parts. Originally it was a 2 LED setup, but I popped one of the LEDs accidentally when I was testing the connections. Oops!
Old May 28, 2004 | 08:20 AM
azrael's Avatar
azrael
looks like good handiwork, but I'm just curious.. what was wrong with the stock shift light?
Old May 28, 2004 | 08:43 AM
ChrisMCagle
Well, there is nothing wrong with it, I just feel like the stock shift light is/was WAY too dim to really be functional. In the daylight you can really only see it if you happen to be looking right at it when it lights up. If you are looking straight through the windshield (like you should when you drive) then it's pretty difficult to see. At least it was for me.
There's no mistaking when it's time to shift now!
Old May 28, 2004 | 12:55 PM
ATI 350z's Avatar
ATI 350z
what a great job! I was going to try to do that, did you hook into the stock light?I just got the pro shift light installed 300 bucks
Old May 28, 2004 | 01:59 PM
04_CS_Z33's Avatar
04_CS_Z33
Does Nismo even make 350Z gauges for the American market? All of their gauges that I have seen seem to be for the Japanese market(km/h instead of mph).
Old May 28, 2004 | 02:18 PM
NY 350Z's Avatar
NY 350Z
hey frank are you commin out tomorrow night?
Old May 28, 2004 | 02:26 PM
ChrisMCagle
Originally posted by ATI 350z
...did you hook into the stock light?...
Well, yes and no. You have to completely disassemble the combo meter to get to the circuit board and then solder a wire onto the board in the right spot. Took a lot of testing to finally figure out where. There is not a wire or anything that you can simply tap into.
Originally posted by 04_CS_Z33
Does Nismo even make 350Z gauges for the American market?...
Nope. They only have the JDM cluster which is all in kph and raises the max speed up to 300 kph (180 mph).
Old May 28, 2004 | 03:55 PM
ZZZealous007
where did u get that sticker from?
Old May 28, 2004 | 09:33 PM
ChrisMCagle
I made it
