MY Freakin Window is Stuck
Old Aug 2, 2004 | 06:22 PM
SangWL's Avatar
SangWL
Default MY Freakin Window is Stuck
GAYYYYYYYYY!!!!!!!!!!!!!!!!!
I"ve read about it and thought it would never happen to me, now my driver side window is stuck, half way too.
gay.
i called nissan, and they said they won't fix it on saturday's, they said only during the week, i work full time and can't afford taking a half day,
is there someting i can do to fix it guys?
thx for the info.
just venting, i don't even want to write any more.
sang
Old Aug 2, 2004 | 07:00 PM
pimp1911's Avatar
pimp1911
Well it happend to me and the temporary fix was to how do you say bang lightly with you hand in the area right above the window switch. Like in the middle of the door. And at the same time hit the window switch, in your case up. It worked for me. So not sure it will help you out. Also I heard the window motor was on back order so keep that in the back of your head when you goto the dealer.
Old Aug 2, 2004 | 07:45 PM
SangWL's Avatar
SangWL
thx bro
i'll try it out tomorrow morning.
sang
Old Aug 3, 2004 | 07:39 AM
Cain96's Avatar
Cain96
your motor might be fried which I would find hard to believe. What were you doing when it happened??? You might want to take your door panel off and reset the motor it's self.
Old Aug 3, 2004 | 08:01 AM
SangWL's Avatar
SangWL
Originally posted by SangWL
thx bro
sang
wierd this afternoon i come to my car and open the door and notice my window started to move, then turned on the car and the freakin thing works now,
wierd
set up an appointment still for streaks and the motor to be replaced
thx though for the help
sang
Old Aug 3, 2004 | 11:49 AM
WeFlyTonight's Avatar
WeFlyTonight
Same here with my window it would start to work sometime and usually it would get stuck when park for awhile. Took it to the dealer and was told the motor was bad. Had to wait a week for the motor because it was on back order. Got a call from the dealer yesterday and the car is at the dealer right now being worked on. I hope it get fix, guess I have to wait for them to call me later today and find out.
Old Aug 3, 2004 | 12:57 PM
erock's Avatar
erock
Quick and easy fix, under warranty. I've had my passenger side motor replaced a couple of months ago, now I'm getting my driver's side replaced..... No biggie, just gotta wait for the parts.
Old Aug 3, 2004 | 01:40 PM
teh215's Avatar
teh215
My passenger window just started to roll itself halfway down after I put it up. I have to hold the switch up for a few seconds after it goes up to get it to stay up. I need to get back to the dealer...
Old Aug 3, 2004 | 01:43 PM
pimp1911's Avatar
pimp1911
Isnt it kinda of funny. The older our Z's get (2003 folks) we experience problems at the same time. Whats next. Lol.
Old Aug 4, 2004 | 09:55 AM
SangWL's Avatar
SangWL
so true, its as if they all age and get efffected together, but thanks to this community and forum, we get things resolved quickly,
i have an appointment on friday so hopefully it will get taken care of.
thx guys
sang
Old Aug 4, 2004 | 11:59 AM
ZRiCaN's Avatar
ZRiCaN
hey for those with the phantom roll down (it rolls down halfway by itself) warranty issue dealer has to replace motor, only way to fix, happen to my drivers side a couple months after owning passenger side a year or so later, gettin that fixed friday.
Old Aug 4, 2004 | 12:18 PM
dczoner's Avatar
dczoner
Yep, get the replacement. I had the EXACT same problem - I think there's a wire that is prone to getting loose on the motor.
I got the motor replaced and its worked perfectly for over a year.
Old Aug 6, 2004 | 04:45 AM
350zOnJuice's Avatar
350zOnJuice
ok i wanna know if i have this problem?? when i autoup the windows they both go up but as soon as the driver side reaches the top it comes right back down half way by itself???
Old Aug 6, 2004 | 07:07 AM
SangWL's Avatar
SangWL
well just to update you guys, i got my car fixed today but now there is another problem. what they did was first off replaced the regulator. that fixed the 10mm window up and down problem when you open and close the door.
but the motor now makes a sound as if it were straining or just not working well, anywho if the problem continues its obviously the motor.
just wanted to update you guys
sang
Old Aug 6, 2004 | 10:23 PM
sticky's Avatar
sticky
I just had the motor changed today, my window was stuck up and not moving at all, they said it is a common problem...
Old Aug 9, 2004 | 06:48 AM
SangWL's Avatar
SangWL
same here, they replaced the regulator and the motor now but htis is the 3rd time comming in, the alignment is way off, so annoying, wind noise now, its so loud, and now this morning going to work i had the window down and now its stuck down.
make sure once they do work with this problem is the alignment is perfect, cause if its off by a 1 mm it will screw things up,
anyways i have an appointment later today i'll keep you guys updated.
sang
Siqcology
Sep 18, 2019 01:45 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
tm9293
North East Marketplace
Oct 29, 2015 02:58 AM
Beater350z
Sep 9, 2015 03:36 PM
AP350z223
Sep 8, 2015 04:38 PM
