Replacing bulbs in 350z
Old Aug 30, 2004 | 04:36 PM
Jun's Avatar
Jun
Default Replacing bulbs in 350z
Two questions:
1. How do you replace the license plate bulbs?
2. I was looking through www.sylvania.com fo the bulb replacement specs and found the following:
Parking light
168
Tail light
7443
Stop light
7443
High mount stop light
%COM
License plate
168
Back up light
7440
Front sidemarker
168
Rear sidemarker
168
Map light
DE3175
Trunk/Cargo area
168
I purchased two pairs of 7443 to replace the Stop light and the Taillight. I was replacing the bulbs, only to notice the the rear tailight consists of the stop light, and the rear sidemarker instead. I don't see where the "taillight" bulb is, there are only two, a 7443 which is the one you brake with and the 168 which is the right under the brake light that stays on when you turn on the lights.
What is this additional "taillight" bulb? Or is the taillight bulb and the stop light bulb= 1 bulb?
Old Aug 30, 2004 | 08:55 PM
ares's Avatar
ares
Veteran
tail light is the low beam 7443, stop light is high beam, 5 and 21w's accordingly all in 1 bulb. the rear sidemarker is also in the tail light to help illuminate it evenly.
liscense plate bulbs... they push towards the center... or away from the center... been a few months, but its pushing them one way or another and they pull down.
Old Aug 31, 2004 | 09:49 AM
Jun's Avatar
Jun
thanks. i'll try later.
hardwood66
Sep 8, 2015 04:31 AM
