Bat's Blackened Headlight Housing, Clear Strip, Clear Sidemarkers and Silverstars!
use to paint headlights a lot for IS300s... no u don't need to prime, sanding it would be good enough. Also, i don't think high temp paint is absolutely necessary, it gives you a peace of mind but its not likely that it would bubble. I painted a few sets of headlights with custom paint to match other people's car (non high temp) and no one has complained of bubbles...
Inventor
Blue Batmobile
Blue Batmobile
Originally posted by zxsaint
Do you prime before painting or just sand?
Wonder how this would look in a matching DB instead of black (if the paint could be somehow made high-temp)
Bat™
yeh very nice....
also, instead of the clear strip..why not paint the orange one with a white base coat and then a coat of light silver
might give the same effect
im gonna do that if Mr zipps cant make clear strips
Zipps, if you can fabricate these clear strips, people are going to be knocking down your door. Please please let us know when you can
Finally I got to see your work and you sir will definately be getting a set of lights from me shortly after you give us the OK on clear strips.
~Josh
Finally I got to see your work and you sir will definately be getting a set of lights from me shortly after you give us the OK on clear strips.~Josh
