Crank angle sensor wire..MUST READ.
Originally posted by westpak
On a separate wiring issue, has anyone checked their codes and seen a knock sensor code? It doesn't trigger the CEL, I only found it because I was clearing a the light for something else a while back and I checked again later and the code was back but no CEL. The code says it is for unusually high voltage, I was getting a new knock sensor to replace it when I did the fuel return system just in case it was the sensor but now with all of the talk on wiring I wander it that is it, specially since it probably has renedered the J&S knock sensor retard useless.
The code was there before TT install.
The problem is that since it doesn't through the CEL but just store a code no one will see it unless they read the codes.
About the crank and cam wires that Phunk will be producing....
Does anyone see the slightest possibility that you would actually need to adjust your engine tuning by simply installing these??
I would think not but wanted some opinions. Just being a worry-wart.
Thanks
Thanks
keeping this crank angle wire a secret makes it seem like some of the sponsers here just want to make money and not offer any help.
"oh your engine blew up with a perfect tune? that's too bad you should've bought my kit instead
I feel pretty well informed about the issue your referring to by reading this forum and by reading a write up on the APS website. So this issue is far from secret nor is the solution. Phunk is offering a shielded wire if you already have a kit that does not provide one. If you have not picked up a kit yet...really don't see why you would buy a kit from a manufacturer that is not addressing the issue. Maybe this anomoly is "over played" because it has not been established how many cars out there are truely effected by it. I suppose this issue could also be responsible for many people in the past blowing rods their their block. Who knows? I am glad the issue has come to light along with a solution.
Forged Performance
Forged Performance
I have big discounts at work from Arrow, Newark, Eutex, Hughes and many other big electronics/wire vendors. I know the GB is already on, but if you want me to get a roll of it I can get a much better price than any individual/small company will.
Forged Performance
Forged Performance
Originally Posted by GMADD
Any updates on the wires ?
My TT install is done just waiting on my Nexus gauges to come in.
Thanks !
Tasso-
Thanks !
Tasso-
Charles??
http://www.************************/350z/350z.htm
Thanks for your help.
I know most people here are looking for performance gain, but I am looking to get my shaky idle back to normal. I just cant stand the idea of paying for a 30K car and not get a smooth idle at all, its like RX-7 all over again. When is the wire going to be ready? I want to order one
did you have an FD?
