Turbo insulator blankets
Old Jan 11, 2005 | 09:48 AM
g356gear's Avatar
g356gear
Default Turbo insulator blankets
Has anyone seen turbo heat insulator blankets for the greddy or APS size turbo's? I have only seen them for Supra's and I know Turbonetics uses one on their single turbo kit. Anybody seen a source for these??
Old Jan 11, 2005 | 11:52 AM
azrael's Avatar
azrael
Talk to Kean from BoostLogic (javeman on this board). I'll bet he could get some made. He provides them for the larger singles used by Supra owners. Seems like a good idea to use them, especially given the turbos' close proximity to the transmission as well as some fuel lines, etc.
Old Jan 11, 2005 | 05:59 PM
g356gear's Avatar
g356gear
That's exactly what I was thinking. The more heat I can keep in the exhaust housing the better.
Old Jan 11, 2005 | 06:22 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Oh man...i cant remember the name of the company that makes these....but they make them for all sizes and style of turbos. Very neat little pieces, and I will likely pic some up during my buildup. they really keep the heat where you want it....inside the manifold and turbo housing.....and they also keep underhood temps down. These shields are a good idea, in addition to heat treating the hot parts.
Old Jan 12, 2005 | 03:40 AM
aalzuhair's Avatar
aalzuhair
Are you talking about this
http://www.heatshieldproducts.com/turbo_kit.htm
Az
Old Jan 12, 2005 | 04:27 PM
g356gear's Avatar
g356gear
That looks like the stuff.....but I have seen someone who sells a pre-formed shield that mounts to the housing. hmmmmm
Old Jan 13, 2005 | 02:27 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Thermo Tec makes them
http://store.summitracing.com/defaul...rbo+insulation
Old Jan 13, 2005 | 04:03 PM
Sharif@Forged
Forged Performance
Z1 and allzuhair posted links to the thermal blanket type designs. THere are also metal pre molded heatsheilds that are even better.......wonder if someone has a link to those.
Old Jan 13, 2005 | 05:15 PM
G3po's Avatar
G3po
Another option, is to get your manis, impeller housings and downpipes ceramic coated. There are several places you can use.
I am having my APS parts coated with 2000degrees in a "gray ice" color.
I am useing these guys since I'm on the west coast.
http://www.performancecoatings.com/headercoatings.html
Old Jan 13, 2005 | 06:10 PM
g356gear's Avatar
g356gear
I did the chrome ceramic coating on the manifolds and downpipes on my Greddy TT kit when I had it. They looked great and I will do it again on my next kit.....but I wanted to find something for the turbo exhaust housing portion of the turbo. Like gq said the preformed type is what I am trying to find.
Old Jan 13, 2005 | 06:17 PM
g356gear's Avatar
g356gear
Found them!!!
http://www.atpwrap.com/albumframeTurbo.htm
Very cool
Old Jan 13, 2005 | 07:45 PM
Sharif@Forged
Forged Performance
Y^^^^^YES^^^^ that is what I was refering too. i think those, coupled with a heat coating would be a perfect combination.,
Old Jan 14, 2005 | 09:42 AM
G3po's Avatar
G3po
Default snail coating
Yes but you can also have the impeller (exhaust snail ) ceramic coated as well ;however a 2000degree or better coating is recommended, Chromex type is not durable enough. Typically the impeller housings are very easy to remove , send of for coating and re-assembly. This "plus" the shields giv tyou a double whammy.
Old Jan 14, 2005 | 11:51 AM
g356gear's Avatar
g356gear
Default Re: snail coating
My only concern is the powder coaters being able to keep the coating out of the critical tolerance areas when the do their process.
Old Jan 14, 2005 | 03:03 PM
Sharif@Forged
Forged Performance
guys...I am checking on the thermal wraps. Might be another GB coming shortly.
Old Jan 14, 2005 | 03:58 PM
G3po's Avatar
G3po
Default Re: Re: snail coating
I guess it could be an issue , but the coater I'm dealing with does it all the time. They also coat the inside with no issues, so they claim
Old Jan 14, 2005 | 07:55 PM
g356gear's Avatar
g356gear
Sent them an e-mail myself lastnight but no reply today.
Old Jan 16, 2005 | 12:02 PM
t32gzz's Avatar
t32gzz
bump for interest in the GB,
Old Jan 16, 2005 | 01:19 PM
phunk's Avatar
phunk
CJ Motorsports
i would buy a pair of those for the greddy twins if you have them made. i have spare turbine housings i could send them if they need something to fit it on.
Old Jan 16, 2005 | 02:51 PM
Sharif@Forged
Forged Performance
I left emails on Friday...should have an answer on Monday.
