vortech install
Old Jan 28, 2005 | 05:16 PM
MCopare's Avatar
MCopare
Default vortech install
Do I need a right angle drill? Can it be installed without one? If so, anyone know where I could buy one? Stores?
Old Jan 28, 2005 | 05:39 PM
2003z's Avatar
2003z
we used a right angle drill adapter, I think it was bought at home depot. Cost $39 and plugs into your standard drill.
Old Jan 28, 2005 | 06:17 PM
MCopare's Avatar
MCopare
shoot...i just bought a dewalt 18V right angle drill....still have receipt.
Old Jan 28, 2005 | 07:39 PM
SungNamZ's Avatar
SungNamZ
You are going to use that Dewalt drill only once. Save the box and all the packing material. Keep it VERY clean before and after, then return.
Old Jan 28, 2005 | 07:43 PM
MCopare's Avatar
MCopare
Wow....great minds think alike! That's my plan.
Old Jan 28, 2005 | 07:46 PM
MCopare's Avatar
MCopare
any other last minute tips before install tomorrow? Should I run the gauges first or last?
Old Jan 29, 2005 | 05:34 AM
2003z's Avatar
2003z
NUC SWO, cool! I did a nuke cruise as a midshipman, bet went aviation instead. I put some tips in this thread:
https://my350z.com/forum/showthread....hreadid=105947
Old Jan 29, 2005 | 06:04 AM
tig488's Avatar
tig488
hell i just installed it lower on the oilpan with a straight drill.
Old Jan 29, 2005 | 06:54 AM
SungNamZ's Avatar
SungNamZ
Didn't check that thread for "tips", but make sure you get a NPT thread tap for the drain plug. Got mine at NAPA. Also, got the crimp pliers at NAPA.
The instructions are good! Take it slow and don't jump around within the instruction manual. I checked things off as I progressed. Welcome to the "FI Club" !
Old Jan 29, 2005 | 07:12 AM
bullseye's Avatar
bullseye
Oh MAN! It makes me sick reading bum advice like this.
I've worked in the hardware business for 29 years, both retail and wholesale. It didn't take me that long to know the difference between right and wrong. If you would rather use the right angle adapter, take the right angle drill back now, and simply exchange it. If you decide to use the right angle drill, keep it.
We're all on the honor system, so do the right thing.
Thank you.
Old Jan 29, 2005 | 09:56 AM
palmerwmd's Avatar
palmerwmd
Thank you.
Even tho I never worked in retail I totally agree.
Unethical behavior is not "great minds thinking alike" it just reflects poorly on who you are as a human being.
Especially considering that no one who is putting a SuperCharger (($$!) on a newer Sports car, they own (!), is hurting for money..
Unbelievable!
Fred..
Old Jan 29, 2005 | 02:14 PM
teh215's Avatar
teh215
I used a regular Makita cordless drill and I got hole very close to where the instructions pictured it.
Old Jan 29, 2005 | 02:15 PM
teh215's Avatar
teh215
Concentrate on the Vortech install first. Do not get side tracked.
Old Jan 29, 2005 | 09:13 PM
MCopare's Avatar
MCopare
Problems.....kit is installed...however., when full throttle, around 4000 rpms, the fuel cuts off? How do I fix this? Anyone have similar experiences?????
Old Jan 30, 2005 | 01:53 AM
booger's Avatar
booger
Many guys have had this problem . Your Aux. fuel pump isnt coming on for some reason . I take it is a new kit and you havent gone into the SS box with a laptop yet , So I dont think it would be the Aux, fuel pump start settings . So your left with... [1 ] fuel pump isnt wired right......[2] Inline fuze is bad.....[3] vacuum line to FMU fell off or has a leak.....[4] either the aux. pump or FMU is defective.
It unlikely that 3 or 4 are your problem . My guess would be your wiring or fuze .
Good luck......hope you find the problem today so you can have some fun . DONT have fun till you fix the problem
Old Jan 30, 2005 | 04:24 AM
MCopare's Avatar
MCopare
thanks for the help booger
Old Jan 30, 2005 | 04:36 AM
booger's Avatar
booger
Maybe one of the guys that had it wired wrong will reply .
Old Jan 30, 2005 | 05:24 AM
SungNamZ's Avatar
SungNamZ
Had this problem, but mine was at 4500 rpm. Took forever to find, but once found felt real "stupid". I am not saying this is it, but I would look here first.
The AUX Fuel Pump has two (2) wires. One (1) power and the other ground. Hard to see while laying under the car, but under that rubber cap they are marked + and -. Start there! It might be a simple as reversing the wires.
Old Jan 30, 2005 | 03:30 PM
MCopare's Avatar
MCopare
Fixed it!!!! All is well and I can now officially say that I have been blown. Good power with no tuning out of the box. Getting on the dyno next weekend and will be tuning. The problem was that we forgot to hook up the power wire for the split second box so aux pump wouldn't come on.
Old Jan 30, 2005 | 06:13 PM
booger's Avatar
booger
Good deal...glad you found it
