Gauges, Gauges, Gauges Which gauges do you really need?
Old Jan 30, 2005 | 05:36 PM
damen's Avatar
damen
Default Gauges, Gauges, Gauges Which gauges do you really need?
well i have a G and i'm planning on going FI (turbo) soon. i really don't want to cludder the interior of the car with gauges. so here are a couple of areas i won't be able to use: the cubby where the stock nav screen goes, i'm planning on going with an aftermarket nav unit so that cubby space along with the cubby above the glove box is no good. i don't want gauges on the pillar because that will give the car a racey look.
here are couple of gauges that i was looking at: Zeitronix Wideband Gauge (https://my350z.com/forum/showthread....hreadid=105051) and the Defi-Link Display VSD Concept (http://www.i-m-racing.com/df05703.html). it seems like both of these gauges should be able to monitor everything that i would need to monitor. the zeitronix gauge can go either in the little sun glass holder or down in the cubby next to the hazard light button is. that's for those of you that know the interior of the '03 G35 coupe. as with the Defi unit i don't think that would look too bad on the dash plus it can show the speed along with tach. on the windshield.
some say that gauges are not needed and some say it's a must. i would feel alittle more comfortable being able to monitor a car that was originally N/A and now FI. i may be able to see if something is not working right and hopefully be able to catch it before it's too late.
there is one gauge holder that goes on the steering wheel column that holds 2 gauges. i'm not too sure about that setup because i don't want to cover any of my stock gauges that i may really need. if it doesn't cover any that may be an option.
now on to which gauges to get? if went with separate gauges which ones are a must? if i were to go with 2 gauges which one are a must and if i go with 3 gauges, which ones should i get? thanks for any replies, if i'm going to get anything i'll have to do it soon, so any replies are greatly appreciated. i know most here have a Z but, there is some really good info here and alot to learn from others. thanks!
Old Jan 30, 2005 | 05:52 PM
g356gear's Avatar
g356gear
I have the Defi gauges in my car...boost, EGT, and oil pressure. I went through the same things as you when trying to find a place for them that would look O.K. and still work. I thought about mounting them in a row above the climate control/clock area. But that was a little far away for quick reference. I ended up mounting them on the sides of the dash pod and I think they look O.K. The gauges are blacked out just like the G when the ignition is turned off and still have the aluminum edge rings to match my aero interior pieces. PM with an e-mail address if you want some pics.
Old Jan 30, 2005 | 06:03 PM
damen's Avatar
damen
thanks for the reply pm sent
Old Jan 30, 2005 | 09:20 PM
350G's Avatar
350G
In functional terms: I would definitely get the boost and A/F or EGT. I personally like the fuel pressure gauge since our vehicles are notorious for dropping pressure at high RPMs unless you've upgraded to a new fuel system (return style). EGT or AF will allow you to tune or monitor the setup (some tuners like one over the other--more preference), while of course a boost gauge lets you monitor the pressure. My Z already has an oil pressure gauge, so Zs really don't need it.
As for looks, I'm not too keen on the two pillar that goes above the steering column . . . it just looks odd IMO. Considering that you have a G and like a bit of sophistication . . . the VSD concept will look great
bcoffee20
Nov 19, 2015 06:39 PM
Calinismo350z
Sep 14, 2015 04:04 PM
