stillen supercharger
Old Mar 20, 2005 | 06:52 PM
itsjoshufocker's Avatar
itsjoshufocker
Default stillen supercharger
hey i was wondering.. if i installed a stillin supercharger, could i still put on a cold air intake, crawford headers, UR pulley, and all them other bolt ons, and make the engine produce even MORE power... or will i have to change everything back to the way it was? im interested in the stillen right now because its the only thing that if i get pulled over and cops check under the hood, im not totally screwd (carb legal).
Old Mar 20, 2005 | 09:26 PM
axxizzer's Avatar
axxizzer
not the UR pulley it will lower your boost, and the Headers would lower your power. The Stillen is designed to run on a stock engine. You can use a cold air.
Old Mar 21, 2005 | 07:13 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
You can use the cold air, but the pulley has to go back to stock.
Also, the headers are questionable. you won't lose power but you will lose boost. the SC kit is designed for use with stock headers so when you free up the backpressure, you will lose boost. I'm unsure to weather you will just lose a little boost but make up for the power in the high end. I don't think losing power all the way through is the case but I'm not 100% sure. I'd leave it stock non-the less and upgrade to a stage 3 pulley on the SC myself.
and of course upgrade the exhaust
Old Mar 21, 2005 | 07:31 PM
nizmoz's Avatar
nizmoz
Tony,
Are you sure I can retain my NISMO CAI with the Stillen Stage 2? Will my NISMO Cat Back Exhaust work okay with Stillen FI? Finally, are the NISMO Clutch, Clutch Cover and Fly Wheel compatible with Stillen FI, or not necessary.
Old Mar 21, 2005 | 09:44 PM
axxizzer's Avatar
axxizzer
absolutely, happy modding.
Old Mar 22, 2005 | 06:58 AM
Tony@Performance
Yes the clutch etc.. will be compatible, i don't understand why they wouldn't be. If you are talking about able to handle the extra power, yes you're fine.
The intake shouldn't be an issue, although stillen recomends that you use their intake/airbox etc...
And yes the nismo exhaust will work just fine.
350Z_Al
Oct 29, 2020 07:44 PM
Bodyboarder81
Nov 2, 2015 12:17 AM
kyin
Oct 15, 2015 05:54 AM
Nicky R
Sep 20, 2015 01:05 PM
Calinismo350z
Sep 14, 2015 04:04 PM
