Vortech install problem
Old Apr 28, 2005 | 05:24 PM
Phaneom's Avatar
Phaneom
Default Vortech install problem
Ok the car start. fuel pressure is at 50 psi. Doesn't seem to be leaking anywhere, cheaked all the vacume lines. The idle is a little bit up and down. When I rev it, it will go up to around 2500-3000 then thats it...it find of start spittering. Does anyone know what the problem could be? would it be something with the ECU hookup?
Old Apr 28, 2005 | 05:26 PM
Phaneom's Avatar
Phaneom
Oh the service engine light.....TCS......SLIP lights are on
Old Apr 28, 2005 | 05:27 PM
zachcrosen's Avatar
zachcrosen
When and where did you get your Vortech from? I ask because I ordered mine 5 weeks ago from Avalon and am still waiting on it! Not dissing anyone just wondering who got yours so quickly. Seems like you ordered yours after I ordered mine, could be wrong though.
Old Apr 28, 2005 | 05:49 PM
gersteinp's Avatar
gersteinp
Be sure to check your connections to the auxilliary fuel pump. If the polarity is reversed, it won't turn on and you won't get fuel pressure above 52 (stock). This is, apparently, a common problem with new installations.
Definitely recheck all your ECU connections if that isn't the problem. It's very easy to screw this up, even with simply a bad solder joint.
Old Apr 28, 2005 | 05:51 PM
Gman2004's Avatar
Gman2004
That normal...everything I have ordered from Avalon has taken a long time. I guess that what you have to deal with to get the best price.
Old Apr 28, 2005 | 05:58 PM
zachcrosen's Avatar
zachcrosen
I have 2 weeks until I need my car to be done for the ZDayZ event. i really hope it gets here next week!
Old Apr 28, 2005 | 06:13 PM
G352NV's Avatar
G352NV
Took me eight weeks to get mine.
Old Apr 28, 2005 | 06:37 PM
zachcrosen's Avatar
zachcrosen
Dont tell me that. 8 weeks will put me getting it at the ZDayZ event time and I wouldnt have time to install. I got word from Paul that the kit shipped from Vortech on 4/22 and he gave me the blower serial number and said it should ship out to me on Monday! I hope I get it next week.
Old Apr 28, 2005 | 06:46 PM
daddyz's Avatar
daddyz
I agree check your connections! Just one loose connection and a problem. Mine did this before and it was a loose solder connection.Good luck and keep us posted.
Old Apr 28, 2005 | 07:20 PM
Phaneom's Avatar
Phaneom
I bought mine from Mississauga, Ontario, Canada. It took them 4 weeks to get it to me. But if you look on Vortech's web site RSM is one of their main distributers. Maybe thats why it came quick.
Anyways with the problem. I checked everything 3 TIME!!! now I rewired the harness back to stock to see if the patch harness was the problem. When I put it back to stock the car runs fine. Then I wired the SS box back in and same problem . I'm gonna have to call them I guess. I was looking at the SS box and saw that it say "2004 350 040128 PROD RLS" My 350Z is a year 2003. Do you think this box was made for a 2004 and would this be where the problem is coming from??????
Old Apr 28, 2005 | 09:36 PM
AmyCroft's Avatar
AmyCroft
Default MAF - Look at the Arrow
Does the MAF have the Arrow pointing to the Throttle Body?
Cheers Amy -
Old Apr 29, 2005 | 02:26 AM
Phaneom's Avatar
Phaneom
There is only one way to connect the TB. One side has a coupling that is connected to the side with the TB, and the other has 4 bolts that is connected to the side that run to the cooler. Plus when I put the ECU back to stock the car runs prefect.
Thank you
Rob
Old Apr 29, 2005 | 03:43 AM
jpc350z's Avatar
jpc350z
If I understand what you are saying, it works fine stock but not with the patch harness " Then I wired the SS box back in and same problem" . Sounds like the problem is with the patch harness? The late 04's and beyond have a wideband o2 sensor but haven't heard anyone mention a problem with these models..
Old Apr 29, 2005 | 06:31 AM
Rogue350z's Avatar
Rogue350z
!!HR TT!!
Trying to help may not affect you:
Do the Kinetix Resonated test pipes have anything in them? Sounds like they don't since they are test pipes.
Anyway my RT cats collapsed with my vortech after I had it tuned. Leading up to the full collapse the idle was bad and the car would bog down over 3,000 RPM.
BTW I have the patch harness as well and did not have your problems after install.
J
Old Apr 29, 2005 | 08:39 AM
Phaneom's Avatar
Phaneom
What I ment was I unhooked all the wires from the SS box leading to the patch harness, and connected the wires back together on the patch harness so that is would be like stock. So with the patch harness connected like it comes stock the car works fine. Once I wire the SS box back into the harness it doesn't work
Old Apr 29, 2005 | 08:41 AM
Phaneom's Avatar
Phaneom
J
They are ressonated so, yes they do have like a mesh around the inside. I don't think that this would be the problem because the cars runs fine with the stock ECU and blower running.
I'm going to call Vortech in a few hours and see what they have to say.
Old Apr 29, 2005 | 09:37 AM
G352NV's Avatar
G352NV
Well go over all your directions for the wiring. Check everything twice! You might also check your fuel connects. I had mine mixed up. I took the car out and it would fall on its face @ 3k rpm. I switched the two lines and the car ran GREAT!
Old Apr 29, 2005 | 09:47 AM
jpc350z's Avatar
jpc350z
Sorry still confused..The patch harness is not stock but I believe you are saying with the patch connected (between both halves of the ECU connector) all is fine..Which say's the patch is good..Seems that if the problem is electrical in nature either you are splicing into the wrong wire(s) in the patch or there is a problem with the S.S box..
Old Apr 29, 2005 | 10:08 AM
zimbo's Avatar
zimbo
What are you using for the wiring diagram? Are you using the Vortech manual or did you use the Nissan service manual that specifically matches your car's model year? The pinouts on the 2003 versus 2004 are NOT THE SAME.
--Steve
Old Apr 29, 2005 | 10:34 AM
Phaneom's Avatar
Phaneom
I used the Vortech manual, Harness manual, and the 2003 350Z service manual to check and mark sure they are all showing the same thing.
These are the pins (terminals) I used.
109 Ignition switch (power)
115 ECM ground
51 Mass air flow sensor
13 Crankshaft position sensor
33 Camshaft position sensor No.1
14 Camshaft position sensor No.2
