Pulley going bad? need help.
Old May 2, 2005 | 07:57 AM
enthuzd's Avatar
enthuzd
Default Pulley going bad? need help.
The tensioner pulley for the main serpentine belt is making a noise that sounds a bit like the sound you get when you put playing cards in the spokes of your bicycle, but a little higher pitched and not as loud certainly. It has slowly become louder over the last few thousand miles...
Comments, suggestions???
Thanks everyone.
Stuart
Old May 2, 2005 | 11:25 AM
booger's Avatar
booger
Stuart
Have you taken it off to look at it . I forgot to tighten mine up and it fell off . But if I remember right , there is a bearing in that pulley . So you should just be able to go get one at the dealer and replace . If that is the problem
Old May 2, 2005 | 04:10 PM
350Zteve's Avatar
350Zteve
Originally Posted by booger
Stuart
Ditto. Double check that everything is at the proper tension and all the pullies are tight.
Justin100
Nov 25, 2021 06:26 AM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Nov 9, 2015 11:10 AM
