Zeitronix Engine Speed Input
Old May 26, 2005 | 01:23 PM
Madelinot's Avatar
Madelinot
Default Zeitronix Engine Speed Input
Hi all,
I'll be wiring my Zeitronic Unit this weekend. I have it all figured out, except one thing. I'm not sure where to get the RPM/Engine Speed signal from. The Infiniti Manual says that the "ECM provides an engine speed signal to the tachometer with CAN communication line." The CAN communication line is terminal #86 on the ECU (Red wire). Is that the correct wire or should I try to use the tachometer input or something? What did you guys use for the RPM input to the Zeitronix box?
Thanks a lot for any hellp you can offer!
Old May 26, 2005 | 04:14 PM
SungNamZ's Avatar
SungNamZ
Innovate Motorsports had a post: http://g35driver.com/forums/showthread.php?t=40388 which indicated ECU Harness Terminal #62 (RPM Signal - Ignition Coil Cyl#1) Yellow/Red.
Old May 26, 2005 | 05:08 PM
Zivman's Avatar
Zivman
Originally Posted by Madelinot
Hi all,
let me know how it goes, I just got my zeitronix unit today.
Old May 26, 2005 | 05:09 PM
Madelinot's Avatar
Madelinot
Great, thanks a lot. I searched here and on G35driver but could not find the answer.
Thanks again,
Old May 26, 2005 | 07:13 PM
SungNamZ's Avatar
SungNamZ
Were you able to find the thread I posted that is on G35driver?
Old May 27, 2005 | 04:00 AM
Madelinot's Avatar
Madelinot
I started last night. Everything should go fine. I found the 3 wires that I wanted (TPS, knock and PRM). I can post more info if you wish later on...
Madelinot's Avatar
Madelinot
No. Wich one is that?
Old May 27, 2005 | 04:25 AM
SungNamZ's Avatar
SungNamZ
The link I posted in my first post to your thread. I am not a member of G35driver, so could not get in to verify.
Old May 27, 2005 | 10:43 AM
BPL's Avatar
BPL
Yep, this is where I have mine connected as was recommended by Zeitronix.
Old May 27, 2005 | 12:09 PM
Madelinot's Avatar
Madelinot
Yes, that's what I used. Great link, thanks!
Old May 27, 2005 | 12:11 PM
Madelinot's Avatar
Madelinot
Just curious. How did you connect to that wire? Did you cut the wire and back together adding another wire? Or just a tap...
Thanks!
Old May 27, 2005 | 05:18 PM
SungNamZ's Avatar
SungNamZ
Striped an area on the ECU harness wire and soldered.
Old May 27, 2005 | 07:54 PM
Madelinot's Avatar
Madelinot
Yeah, that's what I will be doing too.
Thanks!
Old May 27, 2005 | 09:48 PM
KPierson's Avatar
KPierson
Why would you use a coil signal over a crank signal? Remember that your coil signal can be inaccuarate if the ECU pulls timing. The crank signal is ALWAYS accuarate and can NOT be changed under any circumstance.
I wonder if the unit will only accept a 1 pulse per revolution signal?
Old May 28, 2005 | 06:50 PM
booger's Avatar
booger
I think [1 ] pulse per revolution would be correct . You have to set the cyl. at [1 ] instead of [6 ] on the Zietronics
Old May 29, 2005 | 05:31 AM
KPierson's Avatar
KPierson
If it has a 6 cylinder select on it I would definately go with the crank wire. It is a more accurate representation of the RPM signal....
Old May 29, 2005 | 09:14 AM
booger's Avatar
booger
I would email Zietronic's to see if it would work that way . To make sure
Old May 29, 2005 | 03:21 PM
Zivman's Avatar
Zivman
Can we get the zietronix to read Knock?
Old May 29, 2005 | 04:48 PM
Madelinot's Avatar
Madelinot
I connected the user input (#12 wire) of the Zeitronix to ECU pin #15 (white), which is the knock sensor. I'll see tomorow what kind of values I get once I connect it to my laptop.
Later,
Old May 29, 2005 | 06:15 PM
Zivman's Avatar
Zivman
Later,
awesome -
I was going to go with the plx r-500 becuase of it's knock sensor capability. The difficulting in getting my grubby fat hands on one and the $150 premium in price persuaded me to run the zeitronix unit. It would be an unexpected surprise if the zeitronix had the capability as well.
