Troubleshooting codes for E-manage
Old May 27, 2005 | 08:00 PM
richc86's Avatar
richc86
Default Troubleshooting codes for E-manage
Does any one have the trouble shooting codes for the E-manage???
Mine blinks red twice then pauses for about 1.5 to 2 seconds then blinks twice again but quicker then the first time...it keeps repeating the same pattern..
TIA
Old May 27, 2005 | 08:26 PM
Badmonkey's Avatar
Badmonkey
Greddy.com has the manual for the emanage under the tech link. I think that code is 22 for injector #2. The error chart is under the support tool instructions.
Old May 27, 2005 | 08:32 PM
Badmonkey's Avatar
Badmonkey
pg 41
Old May 27, 2005 | 10:34 PM
John at J&S's Avatar
John at J&S
Bad: Do you have the emanage and J&S working together?
Old May 28, 2005 | 09:52 PM
richc86's Avatar
richc86
Excuse my ignorance, but what is the J&S?
I will try to look it up on the tech support from Greddy....
Old May 28, 2005 | 10:01 PM
richc86's Avatar
richc86
Ok I looked @ page 42 but how do I read the error codes?? in other words How do I know it's 22. I see the graph & it shows 11 & 13....
Old May 29, 2005 | 08:56 AM
Badmonkey's Avatar
Badmonkey
John, I do not have the ignition harness working with the J&S. I am still trying to figure it out. I thought the emanage would be able to do its thing after the ecu, the send the updated signals to the safeguard, but it does not work that way, so far. I may try to send it through the J&S first, then manipulate it with the emanage, but this sounds counter-productive. I still need to do some trouble shooting with the emanage. I think my next step will be to bypass the J&S and make sure the emanage works on its own. That may be my issue. I am out of town this weekend and will get busy on it this week, I will keep you posted.
Rich, the codes are decoded in the instruction manual. I can't remember for sure, but I think they are in the emanage manual.
Old May 29, 2005 | 11:01 AM
richc86's Avatar
richc86
Bad Monkey....
Thanx for your help...I got it ...you were right orange/red wire from emanage was not connected to black/red on ECU Inject#2....green light is on & car is running much better!...it is suppose to be orange @ idle then green on rpm's right??
Old May 29, 2005 | 05:57 PM
Badmonkey's Avatar
Badmonkey
I think the light is green when you start and orange when it gets to the AAV voltage. I would have to look at the manual, myself. I am glad I could help out.
etkms
Jun 19, 2022 06:30 PM
350Z Project X
Oct 17, 2015 05:16 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Detailed Image
Sep 11, 2015 04:35 AM
