special thanks to cj motorsports (530whp)
Nicely one Paul, nicely done! so I get to drive it right??
oh yeah people, he has the complete visage kit and sarona fenders. I have seen this car in person, (before the turbo kit) and it was awesome.
hey guys thatnks for all the kind words. it makes me feel a little better about spending all that money heheh. to answer all your questions. i have the jp vizage kit w/ sarona fenders. yes im still using my emanage ( charles can work wonders w/ it). as far as the build goes i just built my shortblock. rods, pistons, head and main studs, fuel system of course, technosquare reflash, ats twin disc clutch, rc 650 injectors, i know im forgetting some other stuff. hehhe, thanks again
congrats paul, the car looks awesome and those numbers are amazing... good luck with the car and enjoy it!
p.s. get back with me if you're still interested in the 3.3 gears - they're still in the box waiting for you!
how much timing being pulled?
what are egt's at WOT?
" " " " cruise? (where is sensor mounted)
THX
TODD
Originally Posted by phunk
pauls car has about 5-6 degrees pulled thru an ECU reflash and I pulled another 5-6 or so by the boost he is running.
i'm assuming that the ecu advances 25 - 26 degrees at most...minus 10-12...so 14?
Its a TS flash. Yes the OBDII shows it running 19-20 degrees of timing from the flash, then minus whatever I put in the E-Manage. The timing could probably have been a little more aggressive.
Paul, I was wondering if you had any trouble with ground clearance with your front end being so low. My car is in the shop getting that front end and I was just wondering about it. Thanks!
