Koyo Radiator and APS kit?
Old Jun 10, 2005 | 08:19 AM
  #41
1G-350Z's Avatar
1G-350Z
Sharif
What do you think of the PE Radiator?
Old Jun 10, 2005 | 12:03 PM
  #42
G3po's Avatar
G3po
Originally Posted by gq_626
^^^A radiator most certainly will effect the temps you see under hot operating conditions^^^
The thermostat stays closed until 175 or 185 F, and then opens. Once the car is above that temp, then the themostat has no control over temps. The fans will kick in, and attempt to drop the temp back down, but under repeated dyno runs, or continuous boost operations, the the themostat is always open, and the fan is always running. When we dyno, coolants temps are always above 200 degrees...and as high as 226degrees. These high temps contribute to detonation, and high under hood temps as well. With a more efficient radiator, these temps will hopefully drop back down to 200 degrees or so...but again..the themostat is still open.
Something to note, if you are runnning the UR pulley , you are also underdriving the waterpump and nece the volume of water. I am running a UR pulley NA, but am changeing it out for a KJR with the Turbos.
SharX59
Sep 30, 2015 10:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
