EGT probe installation.
Old Jun 17, 2005 | 02:50 PM
xxlbeerZ's Avatar
xxlbeerZ
Default EGT probe installation.
Is the wall thickness on our stock headers sufficient to drill & tap for an EGT probe, or do you need a bung welded on? Also, is there room to get in there and drill on the #6 cylinder exhaust manifold exit?
Since I'm doing a single turbo install I will not be removing the headers, and I'd like to drill the hole in the proper place a few inches from the head while on the car. Just want to check if this is even possible.
If I have to weld on a bung, or if it's impossible to get in there, I guess I'll do the gimpy thing and mount it in the collector of one side.
Old Jun 17, 2005 | 02:54 PM
booger's Avatar
booger
Find a way to put it as close to the heads as possible . Only way to get a good usable reading
Old Jun 17, 2005 | 05:43 PM
narkotic's Avatar
narkotic
Have to bung it..
Old Jun 17, 2005 | 06:26 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
do some research for us all!!!
put an EGT on the exhaust manifold and one on a downpipe...
i am very curious as to how much higher the actual temp is at the headers compared to where i have it checked at (downpipe)
Old Jun 17, 2005 | 06:42 PM
Madelinot's Avatar
Madelinot
I tapped a hole on my APS manifold for the EGT probe. You can see it here:
http://www.science.uottawa.ca/~paul/.../G35TT012.html
Really neat job. It would be hard to held a bung on cast iron. In my opinion, it's not needed with the APS manifolds. It's located right at the exit of Cyl #6 before the turbo mounting flange, about 2" from the head. This is the ideal location. I will be installing the kit in 2 weeks once I get the G35 supplemental kit.
Later,
Old Jun 17, 2005 | 06:55 PM
xxlbeerZ's Avatar
xxlbeerZ
I know you can tap a cast manifold, but probably not tubular headers.
Old Jun 17, 2005 | 07:07 PM
booger's Avatar
booger
Have a SC . 1 inch from exhaust port . Hot idle...560 to 590 C. Cruise..610 to 650 C. depending on load . WOT at redline 750 C .
Beater350z
Sep 9, 2015 03:36 PM
