Blew Ignition Coil, ECU - Could it be my Emanage?
Old Jul 7, 2005 | 03:32 PM
  #41
phunk's Avatar
phunk
CJ Motorsports
I have a customers car here to diagnose a problem, he had posted about it on here before but the car was not around for me to check it out... I just glanced at it and immediatly found that the #1 coil is toast... externally visable you can see it has melt down.
This was using the diodes and the latest E-Manage update at the time of tuning, which was maybe 2 months ago? Either way, he got about 3 weeks out of it before this... I havent taken it apart yet to see how many coils are done.
Old Jul 9, 2005 | 08:53 AM
  #42
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Maybe we should stick with version 1.33. That was the one I used for a 1.5years without any blow coils issues.....and no others reported by people using the orginal firmware.
Old Jul 11, 2005 | 01:50 PM
  #43
luanda's Avatar
luanda
Well, I have another update - I just blew two more coils...dealership is basically saying I am on the hook for these ones. On the phone, they said it looks like they are blowing out the side of the coil, so it appears to be electrical in nature, and not heat related.
Gotta find a way to get a beefier coil in there....
This is really pissing me off....
Old Jul 11, 2005 | 01:57 PM
  #44
Sharif@Forged
Forged Performance
Holy cow...what is going on there? How is everything wired up? What kind of diodes? What firmware again?
Old Jul 11, 2005 | 02:00 PM
  #45
luanda's Avatar
luanda
No Diodes....all wiring has been checked...and my tuner is not returning my calls. I am getting rather dissappointed with the guys at Ultimate Racing in TO....not good at returning calls when there are problems....
...just spewing, venting, ranting, raving......
Old Jul 11, 2005 | 02:03 PM
  #46
IceY2K1Max's Avatar
IceY2K1Max
My bet is your short that fried your ECU and coil packs the first time damaged the factory harness somewhere and now it is going to be a PITA to track down where the problem is.
Good luck man.
Old Jul 11, 2005 | 02:08 PM
  #47
luanda's Avatar
luanda
Thanks mate. I am no mechanic, but how do short out the harness? I mean electronic modules I understand, but does the voltage to the coils really get high enough to melt wire in the harness?? I emans that's the only way to short out the wire right??
Good luck man.
Old Jul 11, 2005 | 02:12 PM
  #48
Sharif@Forged
Forged Performance
The problem isnt in the harness wiring per se. The lack of diodes is keeping the voltage a little bit too high coming out of the eManage.
Luanda, you need your tuner to install some diodes on the output wires, ...before risking another set of coils, IMHO.
Old Jul 11, 2005 | 02:21 PM
  #49
IceY2K1Max's Avatar
IceY2K1Max
I'm calling your "wire threads poking through the shrinkwrap" a short, since it was probably a hot wire that touched ground.
When you "short" a wire like that, you can cause large amounts of heat which can melt insulation anywhere along that wire or who knows what kind of damage. Now, whenever you're driving down the road, that bare/naked spot of wiring or damaged section could be touching something else that is causing that.
Just a guess though man...but in my limited experience something serious enough to short out an ECU *COULD* have caused some damage elsewhere, which is leading to more burnt coils. Maybe even the eManage got damaged, I don't know.
Old Jul 11, 2005 | 02:39 PM
  #50
phunk's Avatar
phunk
CJ Motorsports
eek what a nightmare.
I have a customers car that was doing fine for about a year. then a few months ago we put in the fuel system, and all was good.
then we put in the ignition harness WITH diodes and everything WAS good for maybe 3 weeks.
his car started its fun by misfiring a cylinder or two when the engine was cold started in the morn, then ran fine after warmup. Then it got to the point where the car ALWAYS ran like ****, missing a cylinder or two.
Now the car is back here, and its easy to see at least the one fried ignition coil melted out the side. The question is how to make it so this doesnt happen again. We might end up taking the timing harness out for now.
Old Jul 11, 2005 | 02:44 PM
  #51
luanda's Avatar
luanda
Charles,
What about trying different diodes that John was suggesting earlier (below) ...would/could that make a material difference in you mind??
I tried quoting thse numbers to the guy at Radio Shack, and that didn't work....have to figure the SKU #....arghhh.....
Originally Posted by John at J&S
The important spec is the Vf (forward voltage drop). The amp rating of the diodes is not important in this application.
Normally, a high Vf is considered a shortcoming, but we are exploiting it to drop the emanage output voltage.
http://www.fairchildsemi.com/ds/1N/1N4002.pdf
http://www.fairchildsemi.com/ds/1N/1N5400.pdf
The Vf graph shows that the 1N4002 series would be a better choice, since it has a higher Vf at the minimal current coming out of the emanage.
Old Jul 11, 2005 | 02:47 PM
  #52
sentry65's Avatar
sentry65
the burninator
wait so now there's two cars out there using the emanage with the ignition harness and they're both blowing up coils?
sounds suspicious about the emanage....
Old Jul 11, 2005 | 02:57 PM
  #53
phunk's Avatar
phunk
CJ Motorsports
i just dont know about the diodes thing... i have a couple customer cars running around without the diodes and after they picked up their car I never heard a single complaint.
this particular car I spoke of in the last post, he had the diodes, but when the cold missfiring started he pulled the diodes out to see if maybe they themselves were causing a problem, but by then the damage was done and it made no difference.
Old Jul 11, 2005 | 03:04 PM
  #54
Badmonkey's Avatar
Badmonkey
I think a good solution is to not use the emanage to pull timing and use the J&S.
Old Jul 11, 2005 | 03:32 PM
  #55
Sharif@Forged
Forged Performance
Ice, the original issue was when the wires were coming through the wrap (horrible sentence structure..so sorry). But IIRC, and I havent reread this entire post, so forgive me if I missed it....but after that wiring issue was sorted out, he burned another set of coils (or a couple of them) and was not running diodes.
Even in Phunk's case, the diodes were taken out...then the melted coils.
I can tell you that myself, and about 30-50 other customers, and a bunch of SGP's customers have all run the diodes, and never had a melted coil pack.
I have some extra coils on order, so when the Emanage Ultimate is tested on our car, I might get adventerous and test it without coils. I can put a multi-meter on the output wires, and check for higher than normal voltage as well......shouldnt be too hard to determine if the new EU runs lower voltage than the blue E.
Old Jul 11, 2005 | 03:34 PM
  #56
Sharif@Forged
Forged Performance
The J&S is a good solution, but does profile the total and precise control over timing, that many of us need. It's method of reducing timing is either RPM based (x degree of timing retard for every 1000rpm), or boost dependent (1 degree of timing retard for every psi of boost). But if you want to precisely dial in timing, in a long linear fashion, then the eManage is your solution.
I hope John can get the J&S working WITH the timing harness, so the J&S can be the safegaurd..not the main timing adjuster.
Old Jul 11, 2005 | 03:36 PM
  #57
Badmonkey's Avatar
Badmonkey
Sharif,
Do you have access to an O-Scope? It will tell you how much the voltage is for the trigger as well as any static voltage. John from J&S and I will further our testing to the emanage ultimate once it arrives. I am curious if there is a difference in trigger voltage and static voltage.
Old Jul 11, 2005 | 03:40 PM
  #58
AmyCroft's Avatar
AmyCroft
Default HUH ? Did you mean "without Diodes"
Originally Posted by Sharif@Forged
Ice,
I have some extra coils on order, so when the Emanage Ultimate is tested on our car, I might get adventerous and test it without coils. <------ ????
Cheers Amy -
Old Jul 11, 2005 | 04:28 PM
  #59
richsrq's Avatar
richsrq
Luanda, I was fortunate enough for the first 12 months not to have any problems with my coils then I had burnt 5 coils in 1 tank of gas. I was getting random multiple misfire then losing a coil a little while later. I think because of the heat of summer was making the wrap soft on the wires and was allowing the sharp edges to poke through or to get interference with other wires wraped up and bound tight next to each other. The only thing I have done to correct this problem is that I pulled the engine harness through the firewall and rewraped all of the ignition harness wires and I had seperated them from each other a little bit and I took one peice of electrical tape for each wire and ran it length wise and folded it around the wire to give a little extra protection from each other and everthing is fine now. Knock on wood!!! I would get a random multiple misfire when ever I would hammer it and now I do not have that problem either, You might want to buy the diodes and install them and rewrap those wires. I am no mechanic and I installed my TT and did the diodes myself. You can do it yourself and sava some money. I hope this might help. Rich
Old Jul 11, 2005 | 04:47 PM
  #60
phunk's Avatar
phunk
CJ Motorsports
shariff, my customers car fried the coils before taking out the diodes. he removed the diodes incase they were causing the problem.
