problem with vortech/r4
Old Jul 5, 2005 | 11:55 AM
backagain's Avatar
backagain
Default problem with vortech/r4
was washing the car today, decided to wash the engine bay off, when i crank the car, it sputters, watching my a/f gauge reads out extremely rich, say around 10-12. when i rev it up, it sputters some more and the a/f goes up, instead of dropping down, and all the engine bay lights are on. check engine light, slip light, ect, i was in the process of putting on the bypass valve filter, it wouldn't fit with the way the bypass valve was pointing so i decided to take it off and point it the other direction, car would die as soon as it was cranked. so took the filter off and pointed the bypass valve the original direction. any ideas as to what it could be, is it possible that water could have gotten in the ss box while i washing it ? and water do to my car what im describing ? thanks.
Old Jul 5, 2005 | 12:05 PM
G352NV's Avatar
G352NV
Its the SS box. Mine did this a few days ago. Took a couple days to dry out.
Old Jul 5, 2005 | 12:07 PM
backagain's Avatar
backagain
did your lights come on the dash as well ? i rev up the engine and it will get to 3k and i feel a shutter from the engine bay, feels like engine timing is off, probably from ss box no working right ?
Old Jul 5, 2005 | 12:51 PM
booger's Avatar
booger
If you can...Push it out into the sun and pop the hood . Take off the cover for the battery , so the sun can beat down on it . If you have an air compressor , try blowing every thing off .
Old Jul 5, 2005 | 04:14 PM
backagain's Avatar
backagain
did that, same thing as of right now, i was able to hook up the laptop to the ss box and get readings from the system, would it be able to do this if it was the ss box was messed up ?
Old Jul 5, 2005 | 04:41 PM
booger's Avatar
booger
It's possible you have shorted the SS box out . Put a fan on the battery compartment over night , it may just take time to dry it all out . Lets hope so . Let us know
Old Jul 5, 2005 | 04:59 PM
G352NV's Avatar
G352NV
Took mine two days in the HOT SUN!
backagain's Avatar
backagain
i disconnected the battery, how long should it take to reset the ecu ? it's been off for like 30 min so far.
Old Jul 5, 2005 | 05:01 PM
booger's Avatar
booger
thought it was 12 hours
Old Jul 5, 2005 | 05:11 PM
backagain's Avatar
backagain
damn, oh well, can't drive it anywhere like it is now
Old Jul 5, 2005 | 08:18 PM
backagain's Avatar
backagain
ok, i hooked it back up after reading that it only takes 30 min for the ecu reset. car would not stay cranked after this, which was different than what it was doing before. loaded the fuel/timing map back to the ss box and car is running normal. just letting everyone know it's all good for now, haven't driven the car yet, i'll get back to you tomorrow.
Old Jul 6, 2005 | 03:52 AM
booger's Avatar
booger
Good to hear . Must have shorted it out and it did some thing to the program . Good to hear that it only takes 30 min. to do a reset . Thought for sure TS said it took 12 hours .
Old Jul 6, 2005 | 08:42 AM
backagain's Avatar
backagain
ok, got in the car this morning, cranked it up, it died !!!, got the laptop back out, uploaded the map again, car seems to be running fine now, havne't driven it yet, just reving up the engine. any idea what would make the car lose the map overnight ? also would the map have anything to do with the car not staying cranked even at idle ?
Old Jul 6, 2005 | 08:45 AM
booger's Avatar
booger
My only guess is , after you put the maps back in . It still was wet and it shorted again
Old Jul 6, 2005 | 09:06 AM
jpc350z's Avatar
jpc350z
Possibility of damage to the programmable portion of the SS box..When it shuts down the re-write disappears? Will it re-start right after a shut off?
Old Jul 6, 2005 | 09:16 AM
backagain's Avatar
backagain
reloaded it, cranked car, ran fine, turned off car, came inside, went back out few min later, cranked car, died, cranked up, droved around the block, when i got home car was running fine, it is raining pretty bad here from tropical storm cindy, possibly moisture is still in there. car is running ok, got on it pretty hard in first, and it was running just fine.
Old Jul 6, 2005 | 09:28 AM
booger's Avatar
booger
cool..Just takes time to dry out . Guess you wouldnt be washing the engine bay again any time soon !!!!
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
