Spark plugs for FI application?
Old Jul 21, 2005 | 02:54 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Default Spark plugs for FI application?
I'm assuming since my APS TT kit didn't come with spark plugs that the stockers are just fine. Only problem is my stockers already have almost 40K miles on them and I'd like to replace them.
Should I just get a set of stock replacement platinums or go with something else? Maybe a cooler heat range? What spark plus are the rest of you guy running with FI?
Old Jul 21, 2005 | 04:05 AM
SungNamZ's Avatar
SungNamZ
NGK Iridium: LFR6AIX-11 (one step colder) at: www.vividracing.com Good price and service!
Old Jul 21, 2005 | 05:10 AM
mcduck's Avatar
mcduck
I've run both copper and iridium since going FI (both 1-step colder). Absolutely no difference in performance or longevity. Buy what you want, but IMO no point in spending extra on iridium. Definitely go 1-step colder, tho.
Old Jul 21, 2005 | 06:57 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
We've always run the NGK Iridum one step colder than stock. No complaints at all. Iridium tends to hold up to heat better than coopers as well.
We always carry about 10 sets in stock: http://www.forgedinternals.com/store...cat=264&page=1
Old Jul 21, 2005 | 07:32 AM
MardiGrasMax's Avatar
MardiGrasMax
It was my experiance that the iridums are less prone to spark blow out at the same gap versus the coppers.
dirtroad's Avatar
dirtroad
My installer recommended I use stock for my APS ST. I don't know what to do? Why 1 step colder, does it help performance?
Old Jul 21, 2005 | 08:12 AM
xxlbeerZ's Avatar
xxlbeerZ
One step colder is for additional safety.
The APS manual states to use one step colder plugs for my environment. I will do what they say since they engineered the thing. I got my Iridiums from Sharif.
Old Jul 21, 2005 | 08:22 AM
Jaki's Avatar
Jaki
I also use the NGK Iridium 1 step colder spark plugs.
Old Jul 21, 2005 | 08:29 AM
ARLETOS 350Z's Avatar
ARLETOS 350Z
I use IKH 20 for 100shot nitrous
Old Jul 21, 2005 | 08:34 AM
dirtroad's Avatar
dirtroad
So for hotter climates it's recommended? Can't get much hotter than Vegas. For safety: that means less likely to damage the engine?
Old Jul 21, 2005 | 08:40 AM
CpraceZ's Avatar
CpraceZ
Stick with the one stage cooler you will be very happy with them NGK LFR6A1X11 let me know if you need any.
Old Jul 21, 2005 | 09:00 AM
taurran's Avatar
taurran
Yup, Im using the NGK Iridium 1-step's as well.
Old Jul 21, 2005 | 09:04 AM
1 2 NV's Avatar
1 2 NV
+1
Old Jul 21, 2005 | 11:43 AM
amolaver's Avatar
amolaver
does anyone have the copper plug part number? 1 and 2 steps colder than stock?
Old Jul 21, 2005 | 12:15 PM
zero2prove's Avatar
zero2prove
I do not believe these plugs can be found in copper or even platinum. I've looked and looked.
Tuan
Old Jul 21, 2005 | 12:24 PM
Peking's Avatar
Peking
Also so am I, um to the starter of the thread... Kinda "Boosting" 101 (using colder plugs)
Old Jul 21, 2005 | 12:34 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Thanks for all the replies guys! I guess I'll be going with 1 step colder iridium plugs.
Old Jul 21, 2005 | 12:54 PM
mcduck's Avatar
mcduck
Tuan
Sure they can. I'm running copper now with my Vortech. I ran Copper 1-step colder when we first installed it. Switched to Iridium 1-step colder at 10K miles with Vortech. At 20K miles with Vortech, I switched **back** to copper 1-step colder because under FI application there was no discernable difference in performance or wear between the copper plugs I pulled out 10K miles and the Iridium I pulled out at 20K miles.
A search on this forum should yield the correct NGK Copper plug part #. I'll try to remember to post it after I get home tonight.
Old Jul 21, 2005 | 04:14 PM
zero2prove's Avatar
zero2prove
LFR6A-11 is the part number for the copper plugs. I was thinking in the 7 heat range . They don't make copper in the 7 . I didn't think about the heat range numbers when I made the original post. Now if someone can find me double platinums for the Z in the 7 heat range that would be great!
Tuan
Old Jul 21, 2005 | 04:37 PM
Sharif@Forged
Forged Performance
Thanks for the order Brian...they shipped today. Tracking info has already been emailed to you.
