Any wastegate options for APS ST?
Old Aug 2, 2005 | 05:12 AM
Jergens's Avatar
Jergens
Default Any wastegate options for APS ST?
Just curious if anyone had any wastegate alternatives for the APS ST unit. I don't want anything too obnoxious but a nice pssht whistle between shifts would be fun.
~Josh
Old Aug 2, 2005 | 05:16 AM
g356gear's Avatar
g356gear
~Josh
I think you are talking about the blow off valve. A couple guys have switched out theirs already. Maybe Greddy Type-S.
Old Aug 4, 2005 | 10:28 AM
Jergens's Avatar
Jergens
Isn't Wastegate another word for Blow Off Valve? Anyhoo thanks for the input
Old Aug 4, 2005 | 10:47 AM
Enron Exec's Avatar
Enron Exec
Na, its 2 different things. A turbo has 2 sides, the Turbine side for the exhaust, and the Compressor side for the Intake. The blow off valve is on the intake pipe and its job is to relief the compressed air between the engine and turbo so as to not to damage the blades on the compressor from all the back pressure created when you let off the gas pedal. The wastegate is on the exhaust and it opens and closes to keep just enough exhaust gases going through the turbine side of the turbo so the compressor side makes the correct amount of boost.
hulkout
Apr 28, 2017 09:00 PM
Tochigi_236
Sep 27, 2015 03:40 PM
