APS monster exhaust
Old Aug 8, 2005 | 06:08 PM
meatbag's Avatar
meatbag
The tips on the new exhaust are straight out of the muffler but the mufflers are angled, so angled tips.
Old Aug 8, 2005 | 07:09 PM
TurboTim's Avatar
TurboTim
Vendor - Former Vendor
A monster exhaust doenst have mufflers like this one here
We will have this system available with HKS Carbon Ti's as well as with straight pipes next month.A straight pipe system will run you about $100 and the Carbon Ti system will be about $1600-1700.We might offer some other muffler options for less money as well.
Old Aug 8, 2005 | 07:47 PM
Z BOY's Avatar
Z BOY
Originally Posted by TurboTim
A monster exhaust doenst have mufflers like this one here .
so where's the muffler part?
Old Aug 8, 2005 | 07:57 PM
TurboTim's Avatar
TurboTim
The mufflers will take the place of the straight pipes behind the tips.Pics will be posted soon.I will start a new thread since I just posted that for fun.
Old Aug 8, 2005 | 11:15 PM
sentry65's Avatar
sentry65
the burninator
just wanted to jump in and say
it's extremely lame that APS's links are always broken and blocked out
that's just flat out petty...
Old Aug 9, 2005 | 12:35 AM
thawk408's Avatar
thawk408
Agreed.
Old Aug 9, 2005 | 05:31 AM
D@ActiveTuning's Avatar
D@ActiveTuning
On the twin turbo...isn't it less optimal to run such a large diameter exhaust? I thought they suggested before to stick around 2.5"?
Old Aug 9, 2005 | 05:42 AM
mojo powered's Avatar
mojo powered
for turbo applications, the larger the diameter, the better. In fact, if you could run with no exhaust at all, it would be optimal.
Unlike NA (for low end torque etc), backpressure does not help turbo applications so the least amount of backpressure you have, the faster the spoolup on your turbos will be and you will make more power for longer in your rev range. That's also why some people are seeing 10+psi on their stock APS maps when they put in test pipes... less backpressure, more boost, more power.
Of course, you'd need to be careful about reducing backpressure too much and overboosting, so everytime you reduce backpressure, the ideal is to retune.
Old Aug 9, 2005 | 06:09 AM
D@ActiveTuning
Are you sure that's right? I don't think you'd want a 5" exhaust for example on a twin turbo. For a single turbo you may want something crazy like that...but on twins, I thought after a certain points, there are losses? I'm basing this also on a Supra buddy, and what he's done to his car.
Old Aug 9, 2005 | 06:24 AM
mojo powered
yes I am sure.. but I also want to make something else clear.. it's not just about diameter when we're talking about reducing the backpressure, it's also about the bends of the exhaust.
A 2.5" twin exhaust that has better bends than a larger diameter twin exhaust with less smooth bends might result in higher performance.
The ultimate is the largest exhaust with the smoothest bends no matter if you have single or twin turbo. After a certain diameter though, the gains will be minimal and eventually hit zero. But you will not lose horsepower by going larger and larger, you just won't make more power after a while and you will make your car louder and louder for no gains. So you'd have to figure out the largest diameter with most gains without going overboard since you are also making the car louder by reducing backpressure by going larger diameter and smoother bends.
That's why good quality performance exhaust are mandrel bent, which preserves the diameter size around the bends without kinking the tubing.
Please keep in mind that everything I said above is valid for single or twin turbo applications ONLY, not NA obviously.
If you're interested to learn more, here is a great article by Cobb Tuning, I hope it will help. http://www.cobbtuning.com/tech/exhaustdesign/index.html
Old Aug 9, 2005 | 06:27 AM
meatbag's Avatar
meatbag
The less restrictive the better. For any turbo. I think on some setups you can gain low end torque with backpressure but its at the sacrifice of spool time and overal power.
Old Aug 9, 2005 | 06:31 AM
Mantis3024's Avatar
Mantis3024
sound clips!
Old Aug 9, 2005 | 06:57 AM
failsafe306's Avatar
failsafe306
TurboTim, are you a sponsor?
Old Sep 4, 2005 | 12:25 PM
meatbag's Avatar
meatbag
Anyone know a release date for the APS exhaust yet?
Old Sep 4, 2005 | 12:26 PM
meatbag's Avatar
meatbag
They now have a G35 system on there site with straight tips
Old Sep 6, 2005 | 04:26 PM
spdkils's Avatar
spdkils
Default TinyURL
Just use tinyurl before posting any APS urls...
http://tinyurl.com/dc22t
Old Sep 9, 2005 | 07:20 AM
atlsupdawg#2's Avatar
atlsupdawg#2
I always remembered this, for some reason:
Think of the exhaust spinning the turbine as you would you blowing a pin wheel. Put any form of restriction behind the pin wheel and it slows down forcing you to blow harder to maintain its speed. Same principle behind a turbo and exhaust tubing. Put a restrictive exhaust on and the turbine slows and diminishes the turbos performance. The only problems with larger exhausts are fitment and clearance issues.
Old Sep 9, 2005 | 07:37 AM
  #38
G352NV's Avatar
G352NV
Must Stop Spending Money!
Old Sep 9, 2005 | 08:21 AM
  #39
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Both of you are mostly correct. The idea is to have an exhuast system that creates zero back pressure, or as close to this as possible. Even on a turbo system, high back pressure will create massive trq down low, at the expense of heat, and power up top...not ideal...and boiderline dangerous.
An exhuast system that is complete open may not be ideal, as an exhuast system can help with exhuast gase scavenging, and can help draw the exhuast gases out of the combustion chamber. And a small amount of back pressure can increase low end trq. It is a very fine line.
That said...true dual 2.5 inch is generally optimal for about 10psi, and anything above that, I would be looking at a 3 inch true dual.
Old Sep 9, 2005 | 10:44 AM
  #40
theking's Avatar
theking
Sharif is the voice of reason(as usual) lol. I'd rather make up for the low end losses with higher duration cams. My car can overheat easily right now at 12psi with the borla td and test pipes. My torque number is higher than my hp number because of this.
