Vortech Question?
Old Aug 22, 2005 | 12:05 PM
LiNks's Avatar
LiNks
Default Vortech Question?
I want to upgrade to the 3.12 pulley on the charger, which fuel injectors do you guys recomend? Also spark plugs? and if there is anything else i need to change for safety please let me know thanks
Old Aug 22, 2005 | 02:21 PM
booger's Avatar
booger
You can do the 3.12 safely with the stock injectors . A retune will be in order though
Old Aug 22, 2005 | 05:11 PM
freezeg35's Avatar
freezeg35
I will be doing the same swap soon as well. Bit off topic, but anyone know what the hose that goes into the vortech supplied air filter do? Reason im asking is im looking at fabing up a custom 3.5 inch od cai that i can run down on top of the i/c. If all works out i will also weld in an inlet for a 1-1.5 inch hose so i can re circulate the bov.
Old Aug 22, 2005 | 05:19 PM
MCopare's Avatar
MCopare
same question
Old Aug 22, 2005 | 05:41 PM
booger's Avatar
booger
its the crank case breather hose . It was hooked up to the stock intake tube . I took mine off and let it dangle and vent . But plan on hooking up a catch can first and then putting it back on the intake to the blower
Old Aug 22, 2005 | 08:00 PM
freezeg35's Avatar
freezeg35
So its fine to let it vent, i dont really need it back to the air filter? Sorry for the semi hi jack.
Old Aug 23, 2005 | 04:57 AM
jpc350z's Avatar
jpc350z
I want to upgrade to the 3.12 pulley on the charger, which fuel injectors do you guys recomend? Also spark plugs? and if there is anything else i need to change for safety please let me know thans
If safety is your concern. I would add a larger fuel pump and look at the injector duty cycle while tuning to make sure not not at or near max duty..RC 440cc would be sufficient. Don't wanna be at or near the point of fuel starvation...
Old Aug 23, 2005 | 05:37 AM
thebigsadler's Avatar
thebigsadler
I've never heard of this being necessary.
I know people running the 2.87 pulley with stock injectores for over 10,000 miles. Tune the car properly and it is good to go.
I have the 3.12 installed on a completely stock setup. Tuned. Will have dyno results this saturday.
Old Aug 23, 2005 | 05:41 AM
thebigsadler
I don't understand that sudden fascination everyone has with an oil catch can.. There is simply not enough blow-by to warrant the time, money and effort involved. Has anyone PROVEN that there is even a considerable amount of blow -by and that it is in fact worthwhile to look into. Yeah, if your air filter is black within a couple thousand miles of having the sc you may want to look into something, but you may also want to factor in dirt, belt dust and etc.
Old Aug 23, 2005 | 06:50 AM
jpc350z's Avatar
jpc350z
It would be extremely useful to know what duty cycle the injectors are running at. Do have any data or know who might have some.. Thanks
CpraceZ's Avatar
CpraceZ
Having bigger injectors is always nice always a little safer, but as a few other people mentioned you can run that pulley on stock injectors. As for the spark plugs I reccomend NGK 6619 which is one stage cooler than stock. I have the plugs, pulleys, and belts in stock, if you have any questions let me know.
Old Aug 23, 2005 | 06:52 AM
jpc350z's Avatar
jpc350z
Do you have injector duty cycle data to evaluate the need for larger ones? . Thanks
Old Aug 23, 2005 | 07:15 AM
CpraceZ's Avatar
CpraceZ
it depends on the other mods done to the car, I have seen some cars swap out the pulleys and hit 8.5psi while others are hitting 10psi
Old Aug 23, 2005 | 07:39 AM
jpc350z's Avatar
jpc350z
I'm not as concerned with hitting a boost pressure as I am with how close to 100% duty cycling are the injectors operating at with smaller pulleys..Any duty cycle data with additional mod's would be very helpful..
Old Aug 23, 2005 | 07:49 AM
CpraceZ's Avatar
CpraceZ
Ill find out from Vortech and let you know
Old Aug 23, 2005 | 09:05 AM
jpc350z's Avatar
jpc350z
Very much appreciate any and all info you can get. Thanks..I' gotta believe a lot of folks are interested..
Old Aug 23, 2005 | 09:10 AM
LiNks's Avatar
LiNks
Thanks for the info........PM sent CpraceZ
Old Aug 23, 2005 | 10:05 AM
CpraceZ's Avatar
CpraceZ
no problem just waiting on a call back when I hear something I will let you all know
Old Aug 23, 2005 | 01:58 PM
booger's Avatar
booger
No fascination..here...Mines been dangling for quite a while . Im running 13.5psi now and a few other plans in the works . Thought it might be helpful to hook it back up . And if you took your plenum off and found black soot or oil in it....yes I would say there is enough blow by to get a catch can .
Old Aug 24, 2005 | 07:32 AM
CpraceZ's Avatar
CpraceZ
Just wanted to let you all know me and Vortech have been emailing back and forth trying to get some information for you guys, but I will let you know when I hear something.
