Ati Limitations?
Old Aug 30, 2005 | 08:51 PM
jy535's Avatar
jy535
Default Ati Limitations?
Right now i currently drive a 2003 350z 6sp, with and ati procharger, pro-1 test pipes, and borla true dual exhaust, i am currently untuned and have been which is dumb and i no, but there are no tuning shops that i no of in new jersey. i had an appointment to go to AAM which is my best bet, but i just cant seem to get down there, its like 3 1/2 hours away. untuned ive been gettin raped by cars, not extremly fast cars, but cars i should be beating, for instance a 2002 camaro z28 with exhaust, and an eagle talon tsi with some work done. right now i wouldn't even break 13's in the 1/4. one guy that installed my supercharger at mrc said he gained 60 whp when he got it tuned, and thats def what im hoping for. heres my dilema.... i'v made an appointment at this place called IDA off texas road in morganville or englishtown, they do alot of older cars and stuff, they were really busy, i couldn't get an appointment til 9-12-05. i dunno if i should go there and have my car tuned or get an ecu from technosquare. also what do i have to do to run more boost? another ? what about gettin an apr plenum? any one thought are appreciated
Old Aug 30, 2005 | 09:56 PM
freezeg35's Avatar
freezeg35
I think your 20 inch wheels and stereo stuff isnt doing you any favors in the performance dept.
Old Aug 30, 2005 | 11:54 PM
Badmonkey's Avatar
Badmonkey
www.procharger.com
To find the name, location, and phone number of a ProCharger dealer near you, please contact an ATI customer service representative at 913-338-2886.
Give them a call and see if the have a shop in your area. You need to get that thing tuned before you blow it up! There is no way in hell, I would be racing an untuned Procharger. You are just asking for trouble. The tune is not that hard to do, just make sure it is done on a dyno with A/F.
Do you have a wideband A/F gauge or a fuel pressure gauge? I would get these as a minimum with a boost gauge. You also need to addrtess timing. The timing curve in the car is detrimental to the engine under boost. I suggest the J&S Safeguard. Remember, even after you get ut tuned, you need to retard the timing. I am guessing that you arew running pretty rich and is keeping your motor intact, or you may be pinging and your ecu is retarding the timing for you.
The best way to go with the Procharger is with 440cc injectors, Walbro fuel pump and an ecu reflash from Technosquare or AAM. This will allow you to get rid of the aux fuel pump and DFMU. The stock fuel injectors are very taxed with the ATI system. When you are at max boost you may be running close to 120 psi of fuel pressure. Something is going to give. Good luck and happy Camaro hunting AFTER the tune. Just my $.02.
Old Aug 31, 2005 | 07:49 AM
wtf no turbo's Avatar
wtf no turbo
Make the trip to AAM.Get the timing reflash from Mike because ati has no timing retard.Put it on the dyno get the a/fs worked out and finished.
Old Aug 31, 2005 | 08:37 AM
Badmonkey's Avatar
Badmonkey
I do like the idea af a re-flash, I have one myself, but you still need to address the fact that you need to re-flashg as you continue to upgrade. I have the re-flash in conjunction with the Emanage Ultimate. You can now advance and retard timing with air/fuel targeting. I am trying to get the J&S to work with the Emanage ignition drivers.
Old Aug 31, 2005 | 08:51 AM
da45king's Avatar
da45king
please do something...make the trip to delaware,....or even NC.....while 2002 z28 are fast.....there is no way a super charged Z should be losse to a stock z28....
Old Aug 31, 2005 | 09:02 AM
jpc350z's Avatar
jpc350z
Indeed find the time and get it tuned at AAM. Mike once had an ATI before he went to a Greddy..+1 for the injector and fuel pump suggestion.
Old Aug 31, 2005 | 10:40 AM
Sins4u33's Avatar
Sins4u33
get it tuned, i would only trust mike to tune my car, he has tuned soo many ati procharged Z's he has the experience and he knows what he's doing, my car is tuned so well and im making great power...i beat heavily modded z28's and camaro ss's all the time, i would highly recommend taking the extra step and getting it tuned by him. theres something wrong if its not doing well against them....
Ben Y
Old Aug 31, 2005 | 10:17 PM
jy535's Avatar
jy535
im prolly just gonna drive it down there and leave it with them and when they get it in they get it in, i have a bike, and i mind as well get it done now before it's to cold to ride it, i was supposed to bring it to aam, but i kinda screwed them...... i couldn't get the car to them...... and i was supposed to. maybe i'll just leave it there and they can get to it when they can...... i def need to get it tuned though, they are the most reputable place around for Z's it just sucks that theyre 3 1/2 hours away.....imma shoot for next monday or sunday
Old Sep 3, 2005 | 03:32 AM
palmerwmd's Avatar
palmerwmd
Originally Posted by Badmonkey_1
www.procharger.com
The best way to go with the Procharger is with 440cc injectors, Walbro fuel pump and an ecu reflash from Technosquare or AAM. .
AAM told me the reflash they gave me cant rescale anything to run bigger injectors, must be Emanage in additioon to reflash..
Old Sep 3, 2005 | 03:34 AM
booger's Avatar
booger
TS can scale the ECU to run up to 700cc injectors I believe . They did mine for the 550's
Old Sep 3, 2005 | 07:54 PM
palmerwmd's Avatar
palmerwmd
Doesnt a TS reflash lock down youe ECU and prevent apiggy back tuneto take it from there ( if more mods).
I dont knwo if this is misinformation just askinbg..
Also my understanding is you can always tune (with different method) on top of a AAM reflash right?
Anyone know for sure?
Fred..
Old Sep 3, 2005 | 08:26 PM
Badmonkey's Avatar
Badmonkey
I have the TS flash and the Emanage Ultimate working just fine together. There is no lock on the flash.
Old Sep 3, 2005 | 08:41 PM
jy535's Avatar
jy535
so what do u people suggest ts flash or aam........
Old Sep 3, 2005 | 08:46 PM
jy535's Avatar
jy535
whats techno square's web page, are they able to make an ecu for my exact modifications......?? they might make my situation easier...... but if i were to go with there ecu, i would still have to dyno tune the car correct?
Old Sep 3, 2005 | 08:48 PM
Badmonkey's Avatar
Badmonkey
I went TS, because I live close. I have not been disappointed,however the flash was not perfect. That is why I bought the Emanage Ultimate, so I can tweak the flash. My car was actually flashed about 10 times over a period of three days, Brian, worked hard to get it close.
Old Sep 3, 2005 | 08:52 PM
Badmonkey's Avatar
Badmonkey
www.technosquareinc.com They will adjust the flash based on your mod list. The flash will be real close and safe. You can then fine tune it with some engine management computer, like the Emanage Ultimate.
Old Sep 3, 2005 | 10:15 PM
AmyCroft's Avatar
AmyCroft
Smile Hey Boss - Talk to Sharif
Sharif is in North Carolina and has a direct to CJmotorsports
try 626-485-2100 private Cell Phone
Or http://www.forgedinternals.com
If you did your reseach you would find a Number = or Less than 400 Rwhp
It is a Vortech and not an ATI right?
Can you get out of your city an drive a bit? 95 South Right?
You need to see more of the country anyway. I know because I lived in Pittsburgh and a trip to Cleaveland in the 50's was a big deal. Ha! !
It might be worth your time....
Old Sep 4, 2005 | 05:41 AM
palmerwmd's Avatar
palmerwmd
PS: Sorry for all my crazy typos, looks like we cant edit our posts?
Old Sep 4, 2005 | 02:21 PM
jy535's Avatar
jy535
badmonkey, u finetuned the flash by your self with the emanage?........
