2005 vortech SC
Old Aug 31, 2005 | 03:57 PM
DXB350Z's Avatar
DXB350Z
Default 2005 vortech SC
hi guys..
i am planning on ordering a vortech SC for my 05 track model 350z...some people said it will work just fine while alot of people said it will not work for many different reasons..one of which is the VVT(variable valve timing)..some mentioned different reasons i cannot recall..
just wanting opinions..has anyone tried this before? will it work?
here are the FULL specs of the car i have:
▪ 3.5-liter DOHC 24-valve V6 engine
294 hp @ 6,200 rpm
37.9 Kg-m @ 4,800 rpm
▪ Emissions — LEV
▪ Continuously Variable Valve Timing Control
System (CVTCS)
▪ High-flow intake system
▪ Nissan Direct Ignition System
▪ Platinum-tipped spark plugs
▪ Electronic drive-by-wire throttle
Brakes
▪ Power-assisted brakes — 11.7" x 0.95"
vented front discs and 11.5" x 0.63"
vented rear discs
▪ Brembo® braking system
4-piston caliper with 12.8" x 1.18"
vented front discs and 2-piston caliper
with 12.7" x 0.87" vented rear discs
▪ 4-wheel Anti-lock Braking System (ABS)
▪ Electronic Brake force Distribution (EBD)
▪ Brake Assist (BA)
Drivetrain
▪ Front mid-mounted engine/rear-wheel drive
▪ Carbon-fiber composite driveshaft
▪ 6-speed close-ratio manual transmission
▪ 5-speed automatic transmission
with manual shift mode
▪ Viscous limited-slip differential
▪ Traction Control System (TCS)
▪ Vehicle Dynamic Control (VDC)
Suspension and Steering
▪ Front: Independent 3-link aluminum-alloy
suspension
▪ Rear: Independent 4-link aluminum-alloy
suspension with aluminum-alloy
subframe
▪ Front and rear stabilizer bars
▪ Front and rear strut bar/brace
▪ Ripple-control shock absorbers
▪ Engine speed-sensitive power-assisted
rack-and-pinion steering
thanks in advance.
Feedback is highly appreciated
Moose
Old Aug 31, 2005 | 03:59 PM
DXB350Z's Avatar
DXB350Z
oh btw..mine is 6MT.. :s
Old Sep 1, 2005 | 06:21 AM
CpraceZ's Avatar
CpraceZ
No the kit will not fit vortech is planning on releasing on here shortly
350Z_Al
Oct 29, 2020 07:44 PM
SonnyWu
Nov 24, 2015 08:19 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
