Required Fabrication for Turbonetics
Old Sep 12, 2005 | 11:01 PM
redline350ZZ's Avatar
redline350ZZ
Default Required Fabrication for Turbonetics
I am planning my install next month.....besides the kit I am getting gauges and either a oil pan or spacer......Will be changing the waste gate spring to 5PSI and requesting a flash to compensate......
Question though is that is there any fabrications that need to be made to the Z....I will have proffesional help so thats not an issue and any tool needed....Im just trying to put together a plan to minimize time....
any tips for the install appreciated....
Old Sep 13, 2005 | 05:42 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
You should not need anything fabricated. I'd recommend wrapping the piping in the exhaust path, it seems to help with heat.
Just curious as to why you are going with the 5psi spring?
Old Sep 13, 2005 | 08:28 AM
redline350ZZ
only want X amount of WHP untill I can change out my clutch...and less wear on the motor for the time being.....I live in HAWAII 320WHP is enough.....for me for now....
Old Sep 13, 2005 | 09:16 AM
MIAPLAYA's Avatar
MIAPLAYA
No fabrication needed...
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
