Blitz SBC i-color Electronic Boost Controller
Old Nov 7, 2005 | 06:04 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
A tiny bit lower would be nice but I'm in.
GB Serious Interest List:
1) 35ounces
2)
3)
4)
5)
Old Nov 7, 2005 | 01:46 PM
KTaylor's Avatar
KTaylor
Im in but will be ordering through Shawn at Bnt Peformance. I have already ordered alot of stuff through them from you so ill tell them to call you about this.
1) 35ounces
2) KTaylor (Color one + the optional harness)
3)
4)
5)
Old Nov 7, 2005 | 04:30 PM
Fairlady_z33's Avatar
Fairlady_z33
does it store data like different boost levellike lets say one graph of 6psi then another one of 8psi. or it just controlls boost
Old Nov 7, 2005 | 04:36 PM
MIAPLAYA's Avatar
MIAPLAYA
It actually allows for 4 different boost settings. Like normal, espresso, showing off, and HOLY CHRIST MY DATES SHIRT JUST BLEW OFF AND SHE HAS NIPPLE RINGS!!!
Old Nov 7, 2005 | 04:53 PM
sbcbaseball's Avatar
sbcbaseball
Im in if this can be in my hands in a month or less.
1) 35ounces
3) SBCBASEBALL(Blitz ID 3 BLACK)
4)
5)
Old Nov 7, 2005 | 05:34 PM
Fairlady_z33
what additional sensors can be used or can be bought i want to use all of the readings it has. does anyone know which are the other
Old Nov 7, 2005 | 06:23 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
LOL...I need to program my boost controllers to have those settings.>>LOL.
Yes....4 presets is correct.
JDM, the is the optional harness, which take most OEM inputs, such as speed signal, RPM..etc. There is also an optional temp and pressure sensor harness, which takes coolant temp or oil pressure signals. I will include all the harnesses and sensors with the GB detail....if anyone wishes to purchase them as well.
Old Nov 7, 2005 | 06:59 PM
taurran's Avatar
taurran
You gotta be kidding me. I ordered an id3 last week (from someone local).
Old Nov 7, 2005 | 07:50 PM
Fairlady_z33
So Sharif you will include all the sensors in the $700 or is that seperate. Becouse my main concern is the boost and the A/F ratio which is very important. So with all the sensors you said i will be able to use all the readings
Old Nov 8, 2005 | 05:11 AM
Sharif@Forged
Forged Performance
The harnesses and sensor arent included in the price. Boost is going to be visible on the console, and the Blitz doesnt have an AF controller, so you still need a wideband sensor/gauge. You can output the wideband signal to the Blitz.
The only sensor available are the temp sensor, and a pressure sensor for oil/fuel.
Old Nov 8, 2005 | 07:52 AM
redline350ZZ's Avatar
redline350ZZ
Does this unit only control boost?? or can it do slight tunes of A/F as well?????
Old Nov 8, 2005 | 08:48 AM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
will this work with the unichip?
Old Nov 8, 2005 | 12:28 PM
Sharif@Forged
Forged Performance
The Unichip uses its own boost control solenoid, so this is not appropriate for use with the APS kits, unless youremove the Unichip, APS boost control solenoid, and install something else to tune it with, such as an EU or UTEC.
Old Nov 8, 2005 | 12:29 PM
Sharif@Forged
Forged Performance
Just a boost controller, and doesnt have the capabilities to tune AF.
Old Nov 8, 2005 | 12:58 PM
Phatmitzu's Avatar
Phatmitzu
Sharif,
Im staying stock motor, so I wont be going over 10 PSI.
So the E-01 is good enough right? Working with the EU.
What other sensors can E-01 use to monitor?
Old Nov 8, 2005 | 01:13 PM
KTaylor's Avatar
KTaylor
i thought it had the option of being used as an a/f ratio gauge?
Old Nov 8, 2005 | 02:02 PM
Sharif@Forged
Forged Performance
Originally Posted by Phatmitzu
Sharif,
Absolutely, the e-01 works perfectly at 10psi.
The e-01, with the external signal harness, can take 2 more analog inputs...you can pick them. A lot of people would display and log their AF ratio on the e-01, for instance.
Old Nov 8, 2005 | 11:18 PM
  #38
xswl0931's Avatar
xswl0931
http://www.blitz-performance.com/main.htm
Blitz implies this is the case
Old Nov 9, 2005 | 05:35 AM
  #39
Sharif@Forged
Forged Performance
The Blitz can display air fuel ratios, but it cannot do so unless you already have a wideband sensor, and can output it to the Blitz. The Blitz does not have a wideband sensor, or wideband controller.
If you have something like an Innovate Wideband, or AEM wideband, can you output that analog signal to the Blitz, and display it.
Old Nov 9, 2005 | 05:49 AM
  #40
Phatmitzu's Avatar
Phatmitzu
Splice the wire? I dont think the plugs are the same. Is it the same case with the GReddy E-01? I have a zeitronix wideband now.
