Anyone with headers on a single turbo?
Originally Posted by tig488
wow those are awesome numbers, thats an avg 75 more hp than others with the TN kit.
Also keep in mind I redline at 7100rpms THANKS TO THE U-TEC!!!!!
Originally Posted by D350Z10
True, but many using advanced Engine management systems with the kit only no other mods are easily making well over 400 whp, It has be proven, in most cases that other engine management units are the most efficent and prosperous ways of finding true clean power!
Yes they are the same pattern of the Dc headers and alphawerks headers so they should fit great.
Also, why would the 7100 rev limiter would give you more power, the power drops off on the 278hp motor well before 7000rpms. Got a dyno sheet?
I should have my utec here shortly. I did the same thing, I was going with Greddy emanage ultimate and I felt universal application opposed to direct fitment plug and play- what could go wrong. Plus the Greddy having the coil drivers burning out on the Z was to me something to consider. The only thing is the Utec looks like DOS format which is dinosaur to the Greddy windows base format. But graffics point and click does not make the car go any faster. I feel it should be user friendly. I will be tuning it myself. I did get the MAP and AFR controller from Turboxs. Also to play it safe I purchased an EGT to view along with A/F. I did not get the knock light as I felt it was redundant since the hertz frequency from the knock sensor is datalogged.
Originally Posted by redline350ZZ
Can a UTEC supplememt a REFLASH???? or is it better to start from scratch...also what are the additional sensors for the UTEC gonna do for us???? like the MAF..
Well back to the original topic- I think I might go with crawford headers since they seem not to have any fitment problems. I will try a dyno with and w/out the headers. I just feel they are an expensive part to put on and for them not to work out.
Originally Posted by taurran
My DC Sports headers fit, but not well. I still had contact with the downpipe.
ndelgro
Mid-Atlantic Marketplace
Sep 7, 2015 04:11 PM
