ati,bov retune, h34
Old Dec 6, 2005 | 12:38 PM
jy535's Avatar
jy535
Default ati,bov retune, h34
I just installed a turbo XS h34 universal blow off valve , and im not sure if i need a retune, right now i have 3 spacer in front of the spring. it runs a lil' ruff at idle.... does n e one else have this bov, also u really can here ****....... do i need to retune....... i didn't even weld it but i figure that there is not enough preasure to blow it off, its on very tight right now......
Old Dec 6, 2005 | 12:45 PM
BlackTuner's Avatar
BlackTuner
If your car is idling rough with the valve installed it is probably due to it being slightly open at idle.
I recommend adding additional shims until it idles better. If it does not idle correctly after adding all 6 shims. You may need to use the stiffer spring. If one was not supplied to you please contact me at the number below.
Thanks,
Jermaine@turboxs.com
Old Dec 7, 2005 | 02:41 PM
jy535's Avatar
jy535
yea i got the spring, so u suggest using all the spring, correct?...... i mean i think adding all prolly might make the diff..... i'll try thanx for the help
Old Dec 8, 2005 | 06:44 AM
RBALDINELLII's Avatar
RBALDINELLII
I didn't put any extra washers in mine and worked great as is.
Old Dec 8, 2005 | 04:05 PM
jy535's Avatar
jy535
so no washers then, i guess i will try that first, your sound n e diff or no?
350Z_Al
Oct 29, 2020 07:44 PM
