My first Dyno with Vortech and Kinetix hi-flow cats
Old Dec 12, 2005 | 07:01 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Good news. If you could though post a dyno plot with A/F we could check on your current tune. Always nice to get a 2nd (or more) opinions....
Old Dec 12, 2005 | 08:35 AM
Rizlam's Avatar
Rizlam
Sure thing. I'll ask for this post-tuning, next week.
Old Dec 12, 2005 | 09:11 AM
huducks's Avatar
huducks
how much boost r u running?
Old Dec 12, 2005 | 09:15 AM
sentry65's Avatar
sentry65
the burninator
seems to me the A/F is too lean, possibly too much timing and you're making a lot of power now.... but maybe not for long. The curves look very jumpy too.
I'm paranoid as hell with taking precautions with FI. Make sure you're hitting 11's around 5k and up. I thought 15 was high for NA, for 15 that's just dangerous
Old Dec 12, 2005 | 09:23 AM
Rizlam's Avatar
Rizlam
all fine - that 15 reading is on idle. Under load, it's hovering around 11/12. My bad for knowing what reading was pertinent.
0.8 bar
Old Dec 12, 2005 | 10:04 AM
huducks's Avatar
huducks
is that off the stock pulley? which boost gauge r u using?
Old Dec 12, 2005 | 11:36 AM
theking's Avatar
theking
Are you sure?? That can't be the stock pulley.
Originally Posted by Rizlam
0.8 bar
Old Dec 12, 2005 | 03:08 PM
Rizlam's Avatar
Rizlam
Yep, stock pulley, and that's what the meter said...
I'll get them to clarify, but it was on screen throughout.
Old Dec 12, 2005 | 03:39 PM
booger's Avatar
booger
I think he said the dyno was crank HP....not whp
Old Dec 12, 2005 | 04:33 PM
huducks's Avatar
huducks
the stock pulley should be making around 0.6 bar of boost. but those numbers sound about rite if thats crank hp.
Old Dec 13, 2005 | 12:04 AM
Rizlam's Avatar
Rizlam
Yes - crank hp
Old Dec 13, 2005 | 12:49 AM
TheMinel's Avatar
TheMinel
lol make yr mind up Stephen will ya ?
Old Dec 13, 2005 | 01:03 AM
Rizlam's Avatar
Rizlam
Tsk - ffs Val - I've never said it was rwhp - try reading the thread
Old Dec 13, 2005 | 03:04 AM
prescience's Avatar
prescience
Steven,
Is it maybe that you are getting 8psi (or about 0.6 bar)? That's what I see on mine
Also unless something has changed dramatically, your AFR should be fine. When I had mine done at same shop as yours, they commented on closeness of numbers. Mine sees a max of about 11.9 at about 1/2 boost (4 psi) and then drops dramatically to 10.2-10.6 range to redline, symptomatic of the Vortech 'rich' base map.
They can lean it out during the tune but when I have it done, I'm gonna have that peak richened slightly - aiming for 11.0-11.6 throughout.
Old Dec 13, 2005 | 09:01 AM
Rizlam's Avatar
Rizlam
They told me it was definitely 0.8bar - so I'm only going on what I was told!
I get similar figures, but slightly leaner. The confusion came from me reporting my *idle* AFM reading - which is much leaner.
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
