06 REVUP lower plenum, gains for FI?
Old Dec 27, 2005 | 11:11 AM
XBS's Avatar
XBS
Veteran
Default 06 REVUP lower plenum, gains for FI?
Hey I have read that with the lower intake plenum on the 06 "REVUP" models, it solves the problem of air starvation to the front two cylinders which makes them run leaner. Anyways it is also suppose to add some horsepower. Just wondering how if anyone knows what gains this with Motordyne spacer should provide on a twin turbo car. Thanks again!
-George
Old Dec 27, 2005 | 11:40 AM
plumpzz's Avatar
plumpzz
Do you have a track model or 287hp model?
nvm jus read ur sig.
I've seen a dyno of one somewhere it gained somewhere around 30whp
Old Dec 27, 2005 | 11:45 AM
phunk's Avatar
phunk
CJ Motorsports
the revup lower plenum features shorter runners then the pre-05 and also a little bit more plenum displacement. It will compliment your spacer very well on the top end. With shorter runners you can always expect a mild torque loss on the bottom and midrange. however, these runners are not INSANELY shorter, they are actually still pretty long.
I think its a great mod for those reving up to and above 7000rpm. shorter runners will contribute quite a bit to higher RPM power, and with your plenum capacity increase with that spacer, it should be very nice.
if the front cylinders were actually starving from air, that would be making them richer, not leaner starving fuel makes leaner.
the stock plenum, especially with a spacer, has some pretty decent displacement for the HP that most boosted 350z/G35 are running around with. But as the HP starts to get crazy, you will start running into an airflow bias which causes uneven cylinder feed. I think you will have your bases covered with the spacer and this revup lower.
Old Dec 27, 2005 | 01:16 PM
XBS's Avatar
XBS
Veteran
Thanks for the input guys, Really appreciate it, I did mean richer just wasnt thinkg right at the moment lol... so then this would be a good compliment to my F/I setup, is anyone modifing these lower plenums for better flow?
Old Dec 27, 2005 | 01:24 PM
phunk's Avatar
phunk
CJ Motorsports
i dont know if i would bother with modifying it. Its a pretty smooth OEM part, with integrated partial velocity stacks. if you were going to do any mods to your intake manifold stuff, you could port match and taper port the runners and match to the cylinder heads... but thats a lot of work to do and typically reserved for a full build up.. the gains wouldnt be very noticable until running the engine to very high boost and very high power.
Old Dec 27, 2005 | 03:55 PM
XBS's Avatar
XBS
Veteran
I am going to be running jwt spec cams with a fully built bottom end, going to be boosting in the 12-14psi range 9:1 compression, what do you think? just the lower plenum and spacer should be good for 15-20 hp under this much boost?
Old Dec 27, 2005 | 08:56 PM
phunk's Avatar
phunk
CJ Motorsports
yea i think you should go for it.
May 30, 2017 03:28 PM
